Not sure. I can tell you that MG makes good shit. I have a bottle of their flux and it works like a charm - very fast wet-out and easy cleanup. They sell on Amazon IIRC.
As long as your boards arenāt greasy, you should be good to just start painting it on. A couple very light layers is better than one heavy one.
Iād go right up to them with the coating, and then put a little dielectric grease in them before plugging together. @B264 has more experience with this than I, hopefully we can coax a couple pearls of wisdom out of him.
Am I able to use a mouse pad as the foam on the inside of my enclosure? I have a some extra large mouse pads that im not usingā¦ and I dont feel like going to the store
I doubt they are conductive/able to short my stuff outā¦ right?
I got half way though my balance leads before I realized this BMS has only 12 leads, do I not connect the positive terminal or the negative terminal? I assume the negative terminal gets skipped since it uses a hard connection for it
making a 12S3P pack. Just making sure that I got it right.
Planning to make three 4S3P packs and place them in series to make 12S3P.
Each 4S3P pack is 6 cells wide and 2 cells thick.
Is this correct?
Do I attach the positive side of each 1S3P cell to make the BMS balance wire?
This isnt your full battery it only has 24 cells. A 12s3p would have 36 It is very hard to determine if it is all correct without the whole configuration.There should be a balance wire coming off of if set cells. This should help you as it is a 12s3p
