Simple 3D-printed NRF remote - Arduino controlled
I’m having an issue where my transmitter won’t boot correctly unless I push the reset button on the nano.
It won’t boot from just turning on the power switch. I get green and blue lights on the nano, but the lcd doesn’t turn on.
It boots correctly 100% of the time when I push the reset button on the nano.
Any likely culprits here? I’ve tried the 10k resister from RX to GND as suggested by @HighMasterGogo… no change. I’ve tried turning it on and wiggling all wires to see if it might be a loose connection or short somewhere - nothing. Transmitter appears to be functioning as expected once the reset button is pressed, so wiring fault seems unlikely.
It may be relevant that the transmitter isn’t 100% completed yet… I’m still waiting on the Hall effect sensor.
Get your hands on a really small ceramic cap to go between reset and ground. I use 22pF caps on all mine
Hmmm… so I just soldered a ceramic capacitor between the RST and GND but it hasn’t fixed the issue.
Just double checking I bought the right thing:
https://www.jaycar.co.nz/22pf-50vdc-ceramic-capacitors-pack-of-2/p/RC5316
Is there anything I should have done with the Arduino out of the box to prepare it? (Other than upload the two/three libraries and flash the code). I’m wondering if there’s some code I’m missing which resets the Arduino when it’s turned on?
Hmm, yeah. Those should work. If it’s still freezing, you’re gonna want to check the wiring on your NRF. If there’s a short there, it can freeze up the whole nano.
Yeah, that’s something I’d be pretty worried about… soldering that NRF was a real MF.
Further information for diagnostic purposes:
  • Remote boots correctly when micro usb connected directly to nano, but not from battery
  • Battery is fully charged
  • Boots every time after reset button pressed
  • Once remote has booted correctly (screen turns on) it pairs with the receiver every time (suggests NRF modules wired correctly?)
  • Receiver doesn’t seem to need any rebooting, gets straight into it every time. But then the receiver doesn’t have an lcd screen, which is the main symptom of the problem with the remote.
Here’s a list of things I’ve tried:
Added 10K resistor from RX to GND
Added 22pF capacitor from RST to GND
Moved 10K resistor, so now from RX to TX
Jumped TX to GND, with 10K resistor between RX and TX
Checked resistance between all points on the NRF chip - confirmed no shorts
Double checked wiring schematic for NRF - confirmed wired correctly.
Checked battery voltage - 4.5V
Checked voltage from boost converter - 5.6V
Tried alternative battery (LG HG2 - 4V) - identical behaviour from remote (won’t boot from turning on switch, boots from pressing reset)
Interesting observation - if I open the circuit by disconnecting the battery, then reconnect the battery, the remote boots correctly. This is leading me to believe the issue is with the switch or the 10K resistor wired to Analog 2 (I’ve connected this to the switch).
EDIT
Can confirm the fault was with the 10K resistor and switch. I had wired the resistor to the side of the switch going to the charging board/battery. This meant the resistor was closing the circuit between the battery and analog pin 2.
I switched the resistor to the other leg of the switch, and everything is working perfectly.
Now the question is whether I should remove the RX resistor and RST capacitor? Any harm having them there if I’m not using them?
ok now I feel a bit confused. I made already other remotes for VESC 4.12. Now on one of min board I moved to Flipsky 6.6 and the remote was working but I didn’t get any real data on the remote. I read that I need to update the library. So I deleted the old VESC library and install the new one https://github.com/SolidGeek/VescUart?files=1. I then dowload the last developer branch https://github.com/SolidGeek/nRF24-Esk8-Remote/tree/development. I opened them up add the library as usual for receiver and transmitter. Change the address on both of them and uploaded
(I wanted to upload a picture but the forum give me error message, please check the links) https://www.dropbox.com/s/2tlu0djbvm7yxgu/IMG_20181020_202301.jpg?dl=0 https://www.dropbox.com/s/hle84j6bbdr7rby/IMG_20181020_202218.jpg?dl=0
All went fine but if I simply test to turn pair the remote with the receiver doesn’t work anymore. Do you know what I am missing? Every time there is something new :laughing: I tested the remote and receiver just by powered the receiver with the PC. Before was working like that.
ah BTW on the VESC 6.6 I am using Ackmaniac firmware, did someone tried with his firmware already the new vesc library?
Thanks guys!
EDIT: @clistpdx man could you give me your opinion. Sorry to bother :grin: I would like to have back the remote in working condition as before
Im having an issue where the reciever wont connect to the remote unless i unplug and replug the PWM cable. It doesnt matter the order I boot up the Board or remotes. Its strange. My only idea is to have a push button on the outside of the case that lets me reboot the nano, but thats a silly solution.
In that case seems like the receiver is freezing. Did you tried to add a mcp130 chip to the receiver? It takes care of the voltage drops. A small 22uF cap should also help in case is easier to find it. You can search for both in the thread.
I followed @SeeTheBridges tutorial, ill have to find how to add that thanks. Which version of the Mcp130 chip should i get? I’m a Mechanical Engineer, electronics are not my best friend
@solidgeek Great work! I didn’t see it in the thread, but I did read that you have some connectivity issues.
Have you noticed and iterated on the position of the Bluetooth Antenna relative to your hand? Bluetooth signal is attenuated due to water and your hand is a big source of water.
Doug
I used this one 10pcs/lot MCP130T-450I / TT MCP130 SOT23-3 new original
That’s strange… I never used any capacitors or something and it always works. I don’t know what unsre doing different. I also just use cheap Chinese nano clones ect.
Now I just use an capacitor to make the hall sensor more stable, but that’s it.
Maybe my software is a bit different? I use my own fork… I developed an version of this remote to use the Adafruit Feather M0 with build in Lipo control and telemetry. An all in one solution.
This shit works awesome. U can even pair new receivers and switch between different boards… solidgerk is not working anymore on this branch. He has some other project at the moment.
I’m having 2 types of disconnects riding my board with this remote, and frankly both terrify me. most often the board just returns to neutral, i improved this by adding an lc filter onto the rx power supply and some caps onto the nrf power on the receiver, still happens a bit though. the second variety locks the board in it’s set power for 2-5 sec, which once nearly resulted in me going under a bus, but there seems to be no way to predict which one will happen, anyone have any ideas short of just adding more caps?
What components are u using? I never had this issue…
I’m using a chinese arduino nano, nrf24 module, got 4 capacitors on the power pads for the nrf24 and another on the power for the arduino
Hi sorry to bother you but seems you are active on this topic, could you please check my previous post?https://www.electric-skateboard.builders/t/simple-3d-printed-nrf-remote-arduino-controlled/28543/1759?u=rey8801 I basically moved to VESC 6.6 and so I used the new library for the UART port. Since there the remote doesn’t pair with the receiver anymore. Am I missing something? Thank you!
the one from the bom, cause there are many chinese ones with bad voltage regulators?
Has nothing todo with the VESC. The UART is completely separated from the paring or anything else.
tune both, remote and receiver into DEBUG by uncommenting the // from // define DEBUG and check the address. Could only be an address issue. Do u use the latest development commit?
You are right about the UART library, cna not be that. It’s just becuase is the only thing different compare to before. I used the last delevopment commit as I linked in the post https://github.com/SolidGeek/nRF24-Esk8-Remote/tree/development. Is it right? Do I still have to add the library or once they are installed in the arduino IDE they will be uploaded automatically? Here the picture of how I did it https://www.dropbox.com/s/2tlu0djbvm7yxgu/IMG_20181020_202301.jpg?dl=0 https://www.dropbox.com/s/hle84j6bbdr7rby/IMG_20181020_202218.jpg?dl=0
Thank you a lot!
Ahhhhh ok, at first remove all the things u added manually. Or simply just delete your sketch and download a new untouched version from the link u posted before. Open the sketch from the transmitter and upload the code without adding anything. Just open the stecht. Adjust the port and push upload.
U added accidentally some code to your sketch image
All this at least is wrong :slight_smile:
