So I thought it would be a larger inner diameter but no that touches all the way on the rim so thereās is still lots of bite. I put about 35lbs and nothing popped out of course Iāll lower it to about 30lbs before I ride test it
No wonder you only had the LY switchblade 40 briefly. I couldnāt find any enclosures for it.
I had it briefly because I obtained one for someone else, and it was here before reshipping it, and I rode it analog a little bit first
Ah. Ok. Iāve pinged a couple of well known enclosure builders here. Both said they havenāt had a chance to make one.
Yeah not sure if you being sarcastic here Hobbywing are very reliable escās within the rc industry and probably the best chinesium manufacturer. Just wouldnāt mind seeing something vesc based from them.
In the meantime Iām still going with sarcasm because thats more up my street and paves the way for battle
I was being genuine. Ive used hobbywing parts before and loved them. Some of them i swear are bulletproof
Sounds like an interesting experiment
Theres a builder here that has an enclosure on a 36. Its on the pic thread not too far back but too far for me to bother lol
Most of my RC speedos are hobbywing. Theyāre pretty good and reliable. Not sure about esk8
https://m.dhgate.com/product/revolver-keychain-the-world-039-s-smallest/405838036.html#pd-109
Im on it
Looking for 40.
Damn it They are good actually. Just put one in my sons (11) hub board and its smooth as silk compared to the old snatchy piece of shit.
Well im glad to hear that they work so well. Ive ridden chinese hub escs before and most of them are horrendous
Itās all fun and games until you accidentally take that to the airport one day
Jokes on you, im too poor to fly. But my cousin has a plane and jokingly said āif i ever need a rideā
Theres no TSA for private 2 seaters
Iām having a bit of trouble figuring out how the motor sprocket fits on to the keywayād motor shaft. I did some searching and realized the small metal tab should go in the keyway, but do the grub screws also need to be tightened down? If so I need a smaller hex key, 2mm is too big. 10mm shaft 10mm ID bore.
How does this thing go on without spinning freely?
You need a 3mm x 3mm x 10-20mm piece of metal to go in the slot.
https:///products/motor-keyway
Cool I have one of those, it came with the chain/sprocket parts and I didnāt know what it was for at first. Is it as simple as slotting it in the keyway with some loctite?
Yes
What angle do rkp trucks stop working? Iāve got 45 degree baseplate/hangar pair on a 31ā deck with about a 20 degree ends and it just doesnāt turn under my weight anymore
