Hello, I have this Li Ion battery of a hoverboard (new condition https://imgur.com/a/ebDjDsV ) is it possible to use this one to power a eboard? If so, would I just be connecting the XT60 to the ESC of the board or am I supposed to do this otherwise. Also how would one be charging this bms? I only see a P-, but donāt I also need a P+ to charge it? Would I be able to charge it with a charger like this? https://hobbyking.com/en_us/imax-b6-50w-5a-charger-discharger-1-6-cells-genuine.html
Hey guys, I need some help rebuilding my evolve GTX. I fried the esc, and have ordered a Focbox unity, with a raptor remote. Now i need help figuring out the BMS. im rebuilding the battery to be a 10s4p with Sony vtc6 cells, and i read that an 80a BMS would be good for this. here is what im looking at : https://buildkitboards.com/products/bestech-bms?variant=16115585319006
Would this be right? and where do i look for a guide on how to hook it to the battery?
Im also wondering if ill be able to use my stock evolve charger with my pretty-much all new setup. everything is being changed except for the motors.
also, not that i care that much, but will i be able to go backwards?
Also @BruSkater a good indication that your belt is aligned perfectly, is that you can hand-turn it forward and watch which side the belt moves to ā and if you then hand-turn it reverse and the belt goes to the opposite side, then itās not quite perfectly aligned. It might work, but itās better if you can get it perfect. Thatās usually indicating the clamp on the hanger might not be perfectly perpendicular.
Yes, I realized that, and in fact it moves around depending the direction, but I find it quite difficult to align the clamp, I did all I could, but when you tight the screws physics is just going to do its thing and move the clamp a bitā¦ But the misalignment seems minor, hope that is not a problemā¦
But getting to the original question, is there a problem to have the belt so close to the wheel @b264?
Iāll be assembling parts tonight. Super excited! I want it to go smoothly, what vesc tool is recommended currently? I am using the Flipsky 4.20 updated resistor version. I think I remember reading that lower voltage was recommended for the initial setup of the vesc, what voltage? I only have my 10s4p and 12v sources available really.
That charger is complete crap. Mboards takes forever to get the product shipped. I can sell you a 10s4p pack with a charge only bms for $315 right now. It will ship within 2 days of your order
To charge a 12s4p 30q you would need a 25a+ charger to charge in 25 minutes. That charger is 1.5a and will take over 10 hours to charge from dead to full
A 25a charge isnt possible on a 4p pack. It will explode
If you donāt specify which cells youāre talking about, you really canāt talk about it at all. Because itās almost certainly false information. Youāre making assumptions and you can cause someone else to have a fire by making assumptions.
