Bestech is a well known brand around here. They have proven to be very safe and reliable. You have to send them a request to get a price
I didnāt really see anyone other using itā¦ But if you want a smart bms you could either go with a DieBiems or some other more known Bluetooth bms modulesā¦ Just use the search function
What @Mich21050 said. You need to sent them a message to get a price. I didnāt have this bms by my own but a lot of people here using this one. Never heard any bad reviews so far.
To me it looks like a 12s1p configā¦
I havenāt seen anyone else using one for esk8, probably for size reasons. Iāve seen several people using them in ebikes though, where space isnāt at quite as much of a premium.
I know the trampa vesc6 (Vedderās reference hardware) can hit 150K. With 4.xx, the generally accepted safe limit is about 60K. I donāt know if thereās been any testing done on the various 6.xx spinoffs.
I was thinking of getting the 150A setting with no screen
Just use blue loctite on the grub screw. Donāt use red. And I wouldnāt even use blue until you ride it about 100 meters and make sure itās okay. Donāt end up going for a 10km joyride either to test it, bolts and screws will start falling out
What size grub screw works?
Whatever size fits your motor pulley. Itās likely the same thread as the bolt next to it.
Sorry I should have been clear, each block is a 6p
Make sure to isolate each block so metal ācanā carrying different negatives wonāt short together. Because that shrink tubing they put on cells is not enough.
I will fish paper each P group thanks for the tip
The same insulation paper as these spacers on the top/positive?
Hey guys I am looking to upgrade my power supply. I am currently using a Hobbyking 105W power supply (currently used at 3A for 4S Lipo charging). When I was buying it I had saved on the power supply to spend it on other more āāimportantāā components like motors and motor mounts.
So now I am looking to upgrade it. I saw the Turnigy Reaktor Pro 240W 16A Power Supply 100~240V AC (US Plug)
My charger is Turnigy Reaktor 250W 10A 1-6S Balance Charger
My question is what you guys think about it and if you think it fits my charger? Or would you suggest a different one?
I have some sheets of self adhesive fishpaper from nkon.nl
Need help for wiring of an antispark with this switch. Is this right?
Would 12mm belts be enough for a dual 6374 motor setup with 6x2 inch pneumatics?
I am having tolerances way below comfortable between components and I think Iād rather have them a bit more spaced outā¦ ~2mm mount to pulley, ~2mm between motor shaft nubs on the bells.
This ādowngradeā in pulley width would allow me quite a lot of space at least between motors, but I donāt know if Iād be snapping belts left right and centerā¦
