NOOO pleaseā¦ Either get a female one or unsolder the connector and solder the wires togetherā¦ Diagram looks good to meā¦
These are super cheap compared to other parts on a boards and can usually get on amazon for like 8-10 for a pack of them with prime.
So Iāve created a couple of topics but donāt need them anymore. How do I close them or should I just leave them open for others to use?
Just put a comment tagging @mmaner to close it and either he or one of the mods will close the thread.
OK, cool thanks
Ok Iāll do that then. Itās just that 10$ + 10$ + 10$ I think Iām around 150$ of additional stuff. I think Iāll go with soldering the wires directly together because I already see myself struggling more trying to solder the flat wires to those connectors than directly to the VESC wires.
Also it looks like I saw this was done already: and it seemed to work soā¦
Thatās not right. Look at the picture you posted, than look at the blue marked spot here
You see the wires where soldered to the right side, not to the pins inside.
hey guys thanks so much for hgepling me out , ive been rideing my board in https://www.betteshanger-park.co.uk/ which is great long truch , board so fast but sadly my brother came on it and now it just cuts out not sure why any idias , i ty recnfigyreing the vesc but nothing, im colour blind but my freaind saw a red light when it cuts out
ive done alot od reserch but still donr know what chould it be , im sure the vesc is configgured correctley
Will an XT30 be enough for a charger? Gonna use it at 50.4V 8A for one battery and 42V 2A for the other
In theory they can take 30A continuous and a 50V spark shouldnāt be long enough to jump the leads
yes Ā
Is it work using XT90s anywhere else besides the loopkey?
No
I would not have two chargers in your house at different voltages (42V, 50.4V) with the same plug on the end. Use a 5.5mm x 2.1mm barrel plug for the 2A one
You can use XT90S anywhere you can use XT90, and the male plug are identical. The female XT90S has a resistor and a ring inside while the female XT90 does not
Help, Bought using a maytech mtdu30a dual esc with their remote. How can I pair/bind my old wowgo/meepo/hobby wing remote to it as the maytech has failed.
When soldering on new wires on old motor wires how much heat is too much? I just tried soldering on a sacrificial motor and those puppies get HOT! Hot enough to melt the enamel? Not sureā¦ But considering I want to shorten the original āsturdyā cables and add longer extensions, I donāt want to melt enamel at the statorā¦
The china stuff you canāt pair new remotes to them. Only if they have a separate receiver and itās not built-in to the ESC. I would contact the seller
How do you find out if vesc is Brocken
