Lovely dog
@dickyho any update on when the mirrored versions will be made? are the belts in your shop correctly labeled now or should we still buy the 295 for 16/36 + idlers?
Do your caliber mounts also work on torqueboards trucks? Also, has anyone tried these on 107s?
Sorry for late reply. They cost me 18$ each and 5 dollars shipping to Canada. Totally worth the money. All the hardware is included as well.
Sorry, not sure, donāt have torqueboards trucks to tryā¦
already asked the vendor to produce, just things go slowly hereā¦, already checked all those belts, all are correct now.
I donāt see why they wouldnātā¦ May have to wedge a piece of shrink wrap in the clamp but tb hangers are just clones of calibers.
TB218 trucks are larger by a little and the profile is just slightly different, which means you might need to file something down.
When my mounts arrive, Iāll test on tb218
Unfortunately the clamp doesnāt fit on tb218. So filing the clamp or the hanger
Did I miss the answer? I got some really wired channel trucks and milled them down to 20.5mm square, so about 29mm diameter, will that fit inside these mounts (I can print (SLA) or laser cut (POM) some spacing so smaller is no problem) ?
Thanks, thats going to be tight, but I hope by loosening the screw it will fit also I do not have pointy edges so it has to fit
This mount will be dope with the new esk8-specific Caliber trucks with the longer axle (can accommodate pulleys that take bearings without having to file-down the hanger).
Never had to File down anything for a pulley. What do you mean by that?
The caliber mounts keep showing out of stock on his ebay store. @dickyho Do you plan on relisting the mounts? I wanted to take advantage of the Ebay coupon that is expiring today.
