I was asking the same question a few days ago, but I don’t know enough about those motors and bearings to be sure if that is doable. Maybe now that we know the bearings number it is possible to find out if there is a suitable replacement.
Looking at the picture it seems that there is a sleeve inside the bearing maybe we could change just that??
I don’t think you can just replace the bearings. The stator must be attached to something, either the axle directly or a bushing type piece. That bushing would need to be drilled out to 12mm and then the bearings swapped for 12mm Id ones. Then it would be usable on a 12mm shaft… maybe
So it can be drilled from 8mm to 12mm. The only problem would be this square part that locks motor to hanger. This whole design can be modified quite easy.
If someone opens it and shows how thick the hub part is and at what diameter it’s stator maybe you could easily drill it out for 12mm but then you need a 12mm hanger with the square end and of a certain length and where to get one. You’ll likely need to get it made. I happen to have a ton of 12mm hangers w 50mm long axles coming out either side. Not square on the end and you’d have to do modifications but could hold you over until some are cast.
BTW… for those that are curious on the completes… Aladdin pants will be in NYC on friday evening with the smaller version of the board if you like to see the actual board or require fashion advice He will be on NYC collective telegram
I’ll do my best to complete a build by then to give people an idea of how these perform, but I can’t promise anything as I’m pretty busy for the rest of the week.
However, I’m sure one of the other people receiving the drives is better equipped to pump out a full build in no time.
