Quick update, I’m building the 12S4P pack.
How would you compare these holy pro builds with the little AT beast? Im a huge fan of the little guy btw
totally different; the AT beast is huge power on a short deck; feeling is like space mountain. The holy pro is more a mountainboard with flex. both are dope. What little guy are you talking about ?
I meant the AT beast cause its “little”
hah yeah
Nice one OKP! You are faster than me. As I can see, you have the MTB Hangers mounted, springs in outer position. What I would recommend is putting extra inserts in for the bindings. Do you need the grip design I made for the Street Carver?
Frank
thanks bro ! how did you plan to close the littles gaps on the deck (foam/epoxy?) nice grip; I take it. I’m probably gonna apply some vicious grip. good job on the enclosure, it’s easy to setup and looks neat.
I’m loving what I see I’m going down the same design lines you are, @okp ! Could you plz share the exact length of your enclosure in the image cited by me above? Thx
Which gaps? The ones in the enclosure? 0.5mm silicon sheet on the inside, that’s it.
Grip design will be plotted to PDF tomorrow. Can’t wait to find the time to finish my board. Lots of work on my desk… Have you seen the Scooters on our page?
Frank
62 cm
I may just go for silicone tube in black color for all the gaps as the silicone sheet is crazy expensive
http://www.castorama.fr/store/Sikaflex-AM-Auto-Marine-noir-300ml-PRDm931701.html
the scooters looks insane as every trampa stuff in reality.
my plan is to ride this and report back this week.
Research the silicone mat well @okp, I’ve found and bought a 1mm-thick one for less than 1EUR per 10x20cm piece, which gives like around 10EUR for a 70x30cm sheet. My source is here, Poland: http://allegro.pl/100x200mm-gr-1mm-plyta-mata-silikonowa-uszczelka-i6760942841.html
1mm is quite thick. EBay is also full of the silicone sheets. Terra elastic training band is also silicone. Nearly nicked my wife’s one… I don’t know if Sika will stick to our material.
Frank
here we go
nice cant wait to see it in real.
She’s certainly one hell of a beauty, @okp !
Tell me plz how much stiffer did it get with the Trampa roadside enclosure with the cut pattern you’ve utilised? Or to be more precise: What ply count is the deck? How many “plys” of stiffness did the enslosure add?
thanks bro. I went for 4 plies for enclosure. @trampa gave really great advices as usual. I’m proud of this build and proud to use VESC6. Thanks Ted, Benjamin, Frank for making this happen. There’s really no glory on my side except bringing hooks to the esk8 scene. But man, I’m just back from a ride and I’m just happy.
Here we go, a quick edit
