All good for me. Thx man!
I would like 2 if possible
Ok. This batch is still in progress. You would need to wait unfortunately
ok, no prob I’ll contact them directly. Thanks for fast response
I can’t see the video
Thanks @moon
Sorry if this has already been asked. If no button is connected, and the vesc gets power, does it then start up like a normal vesc ? Or do we need a button together with this flipsky vesc, to get it going.
Is it to late to join this batch, if i fill out the form tonight ?
I think the answer is
You dont need the button to get this working. If you don’t have the button - which no one has since I didnt order it the vesc will operate like normal
Thanks…
And if i want to use one switch to turn on/off both vesc, i need a 2 way latching switch, with C-NO-NC function ?
You can use one switch. There were pretty good explanations further up.
I have said its too late. Unfortunately.
I didn’t know more people wanted in . More people were filling the polls out but not much form fills
I have seen that diagram. But i dont understand why nothing happen, when you mix two supplys together in one parallel connection. If one 12v supply fails in one vesc, what happens then to the other ?
On my understanding the supply wire is for the led to work on the momentary button. By using one rated for 24V instead of one at 12V you will be able to get current from both the VESC. I do think that get the current from only one is plenty enough. I think that if one 5v line from one vesc fails then the other one is enough for the momentary button to work just fine. @hyperIon1 what do you think about it? Thx
That’s a good question and would only be answered by testing it.
It would depend on the rating of the led. 5-9v and most are 9v
Bought some packaging and came today
Little delay
Basically they have run out of heatsinks. So they are going to make new ones and install them on the 6.6 esc.
They say that the earliest delivery 19 August
I guess hummie got a lot of their current stock
Thanks for the update. No problem at all
Yeah not a huge delay if it i gets shipped on the 20TH of August.
They feel bad and I asked for buttons to be included, I will confirm if its true on Monday
