Ahahah good catch in case
I‘m not in a hurry too. Some more days but button included wouldn’t be that bad😂
Not bad at all. Consider those buttons probably would be ordered from ali for most people
Indeed already ordered
Yep. Ordered also. I will use it on another build.
Ok so some people will have spares if I can get any. Also trying to get red anodized heatsinks, just trying to gets something good from the delays
Red …if that continues like that I can wait even more longer…
Ahahah it is gonna be funny. Keep us post it, is better than a Netflix series Moreover we all known that red colored mean more speed
Of course, except they might run a bit hotter because they are red
True True we should than go for rainbow, more balanced
You could try go to any Retail store and ask if you can take their boxes.
I spent £2.2 on 15 jiffy bags. They are recycled but they feel real good quality Bubble wrap is something I need to get aswell And some ink for my printer
Please link your finding for us lazy guys
Do you mean the momentary button?
yeah yeah. I should probably do some research
The button and the connectors From 2 vesc’s to one switch.
I will just make a direct connection between the two vescs not with a connector in met ween. I do not see the reason to have another connector. Anyhow I picked it up this one. Should work. 16mm Metal Momentary Push Button Switch LED 5V 12V 24V 110V 220V StainlessLess Steel Waterproof Car Auto Engine PC Power Start http://s.aliexpress.com/6Z7JbeMb? fromSns=Copy to Clipboard I liked that it’s only with the circle and not with the to run on sign in it. I got 24V although is still not clear to me why they get the current from both of the VESC and not only from one.
I should already have the JST connector to the VESC but ti be sure @hyperIon1 do you know which 3 Pin JST it is? PH?
EDIT: Here the link for the JST connector https://www.aliexpress.com/item/10-SETS-Mini-Micro-JST-2-0-PH-3-Pin-Connector-plug-with-Wires-Cables-300MM/32823594180.html?spm=a2g0s.13010208.99999999.259.63453c00Vm2RYU
Yes. It’s the same as the rest on the pcb. Ph 2.0 I think.
Major blue balls. Flipsky couldnt get the buttons in the deal or the custom anodizing
FIne, it worthed a try
So no Ferrari mode ok I think i‘m fine with the standard edition too…but the extra speed boost now gone…
