I got parts for 3 of these and am having issues with all of em. I’ll keep diagnosing.
Parts for 3 Vedder Switches? If you figure out what’s wrong make sure to drop that in the Vedder thread to benefit others. Also a good place to deal help would be that thread as well.
Personally I don’t have a VESC, wish I did though, so I can’t tell you exactly how the VESC would behave but, escalating the max amperage can give you more torque because like I said when the motors first start up they draw a lot of current and the VESC may limit that because you set it to 40A max so it would be better to set it higher in that case. Though like I said I don’t know to much about the VESC so I’m not the right person to ask sorry. And the reason the fuse doesn’t blow is because its drawing that current for a very short amount of time so the fuse doesn’t have enough time to heat up and break.
I was reading more about paralleling MOSFETS and you can’t use one resistor for the same gates of the MOSFET’s because they will “fight” over the voltage for the gate capacitance so I have to go and change that on the dual fet circuit’s.
EDIT: Updated images, schm and brd files to accommodate this change.
Yep! Will do.
Dual IRFB7530 version with 12V LED push button integration.
!!!VERY IMPORTANT NOTICE!!!
The gate resistors for the MOSFET('s) can not always be just 10K resistors! I was originally doing this and its wrong! The 2 resistors act as a voltage divider for the gate but you have to make sure the voltage is not over the Vgs max of the MOSFET. For a 12S build you will need a 24-32K Ohm resistor on the positive side and a 10K on the negative side of the voltage divider. For a 10S build 18-25K Ohm on positive side and 10K on negative. For an 8S build 2x 10K’s would be fine but a 12K on the positive side would be better. 6S Build two 10K’s are fine as well. You can also use a mismatch of different resistor values using a Voltage Divider Calculator to calculate the required values, just don’t use any resistors under ~1K Ohms. I put an example below so you can get a better understanding.
USING A 12V ZENER DIODE TO DRIVE THE GATE WOULD BE BEST! Using a 12V Zener would mean the gate always gets 12V no matter what the voltage is, as long as it’s above 12V obviously.
Dude I am totally interested in one of these. I have a 13s 3p lithium battary pack that I made myself for a single drive motor. What is my cheapest option for one of your switches?
@Chicagojoshua - 13s is going to be tough to find an ESC that will work. Most max at 12s. Not sure if the mosfet switch will also be limited to 12s max?
Hey @sl33py my switch uses the IRFB753PPbF MOSFET which has a max voltage of 60V so you could technically use a 14S battery. Also most components that have a max of 12S can probably handle 13S-14S just because not many parts have a max voltage of above 50.4V(12S full charge) and below 60V so usually there max is 60V, not much in between.
Ok,
So which switch do you recommend and how much will it cost me for the LED push button version you make?
Well its up to you on which one you want. Either one will work for your single drive setup though the dual MOSFET one that’s $35 instead of $25 will future proof you more because you’ll be able to use it with a dual drive setup if you ever decide to go that route. If you want the LED Pushbutton its an additional $10 so for the single FET switch it will be $35 and the dual would be $45 though like I said my prices are negotiable.
I will purchase two… one a single drive and another for a future dual drive both with the push button LED. Whats the best price you can quote me?
How much for just a blank pcb posted to uk ? Single 6s setup
A blank PCB for one of the switches? No components just the PCB right? I guess I could send one to you, ive never shipped internationally before so I dont know how much it would be though. I custom make all my PCB’s using a laser printer but you could try using the Toner Transfer method to make one yourself and it would be quite a bit cheaper.
I was wondering if someone could double check me on my switch drawing. Should be essentially the same as @JdogAwesome made.
Looks good though you’d be a lot better off using a 12V Zener Diode’s to drive that MOSFET gate as it’s more stable at different voltages, other than that looks great!
Cool, appreciate the tip! Also I believe you may have told me a while back But I’m still confused on the purpose of the diode (1N5404) I believe you (or maybe it was someone else) said it had to do with the regenerative breaking? But how does it help / what exactly does it do?
