So I can only get 3 bolts in, other than getting out a drill and taking down those plastic nubs in the core I don’t see how I can get the remaining 3. Am I just doing something wrong?
Is it even worth getting all 6 in? I’m tempted to just call it good with 3.
Kinda disappointing, why make a special pulley for an abec core if it requires drilling.
Nah, my assumption is that these pulley mounts are just like that. Maybe they’re made for the 85mm and those are different? I dunno. I’ll try their live chat tomorrow though
Every abec core ive used is the same 85, 90,97 and 107mm.
I doubt it’s “these pullys are just like that”
A lot of members here use them and it’s the first ive seen this issue.
I had to use a 6mm drill just to make sure the bolts could go in straight. Had the same issue.
It’s quick and easy. The material you remove with the drill is minimal.
If you want wheel pulleys with tight tolerances, I have some for abec core and 12mm belts on my website. Soon I will have for 15mm belts also for abec and kegels.
