But you get better alignment with 6 bolts imo
The Torqueboards Abec wheel pulleys only fit 3, you did it right, don’t worry!
Theres different abec cores, the TB ones are made to fit the clones those have a slightly different core. (They atleast fit perfect on my clones but only 3 bolts on my geniue where my geniue abec core ones have a smaller pulley)
Did you use the front plate as a drill guide?
Awesome thanks man, I’m probably just gonna leave it be then
Nope, just drilled with a 6mm where the bolts would go. Honestly it’s a minimal amount that gets removed. You can’t tell that it’s been drilled
Then how come 6 bolts come with the set?
6 Bolts are used for ABEC Clones and 3 Bolts are used for ABEC11 Flywheels.
