Certified FOCBOX Suppliers | Get Focbox Unity
VESC problem. motor won't spin
#1
I assembled my esk8 last week and I rode for an hour withouth problem. Yesterday my friend was testing and it stopped. When he come back a phase motor wire was loose. I connected again but not response from the motor.
I have check all the conection, I’ve tried another motor and still no response. Also I’ve changed the battery for a power supply in order to check all the component so I tend to think that the problem is in the Vesc but not sure.
My Vesc is a 4.12 turnigy.
There are apparently no burnt or damage component. I can connect to PC and receive response. Light green/blue ON. No faults on terminal. Firmware updated again.
Everything seem OK but when I try to config the motor no spin nor other sound.
Any advice in how to confirm that is my VESC that is broken?
Setup:
sk3 6374 168kv
2x6s 4,5 lipo turnigy 40c
vesc 4.12 turnigy
BMS (Chinese bypassing) -> Removed to test
Screenshots of the results
Firmware
Motor config FOC mode results
Realtime data
spinning the motor by hand
#2
With everything plugged up and on, check to see if your fet on the vesc is getting hot. If so, its popped inside.
#3
No, it’s cold.
#4
Do you have a voltmeter? If so, check voltage throughout the system. You may have a loose connection on the vesc or leads in motor came off… Not being able to see it does leave us in the dark though.
#5
go on vesc terminal and type fault to check for errors
#6
Yes, I tested in all points and everything seem correct except inside the VESC because it has the transparent insulate. I will broke to test it but the VESC indicates a correct voltage.
I’ve added some screenshots in the first post.
No faults
#7
thats good…no DRV fault. did you try to do motor detection again?..just for the sake of it
edit: just saw that you tried that
#8
@DaniRC
Try to reset the values to default and then give it a try.
Also check by re-flashing the fimeware on FOCBOX again
#9
I did and it didn’t work but I will try again with crossed fingers :relieved:
#10
It think that is a DRV problem. I’ve broken the insulate because it had an sticker and I wan’t able to see the last corner. Although I don’t have any DRV fault, it seem that it is burned.
#11
any place to repair in Europe?
#12
@Martinsp :smile:
#13
@DaniRC These ESCs are not good. Have you tried FOCBOX?
#14
No yet but I’m going to buy a new Vesc. Don’t have focbox the drv issue? It cost more than double with shipping to Spain… Three times if I include the additional warranty :cold_face:
#15
@DaniRC Let me help you get a FOCBOX
#16
Yes, try it
#17
@DaniRC
We have reseller available, have you checked them?
