No, no new Android version. Thanks for thinking on it, though.
Does anyone else have any ideas why the app doesnāt work? Now it works, connects to the boards, but doesnāt show data other than zeros, even if I reboot. @Ackmaniac?
Hi, one question if possible. I now have the bluetooth module connecte to the slave VESC because I built a FireFly remote that needs the UART port too. I enable send over CAN ā0ā in the app and I can change the setting eccā¦ the only thing that doesnāt write on the master is the throttle/brake curve adjustments. I donāt remember whether it is suppose to do it now? Not a big deal because I use the TCP connection to fix it, but just out of curiosity. Thx!
It is important to deactivate āSend status over CANā at the master. Please check that.
You are totally right, it was on. I do not remember that I changed it. Now it works! Perfect, thanks!
Is there a reason the app shouldnāt work with vedders new nrf51 Bluetooth dongle firmware?
No idea. Never gave it a try.
Iāll report back.
Only for master
yeah I just figured it out. IĀ“m an idiot
I canāt connect to raptor 2 anymore on Nokia 7 plus(android 8.1) can see device in bt settings but not in app?
My bluetooth module works only on the slave vesc. What could be the issues why itās not working on my master? Connected to master it says āno esc connectedā (Focboxes)
Did you set the same UART Baudrate? And did you choose PPM+UART as control mode.
Yes I did. But going to double check it now when I have the enclosure off. Una momento
Lol I had accidently pressed āwrite motor configā instead of write app configā¦ All good now
When I change a mode for dual setup, only master vesc is changed. Bluetooth module connected to masterā¦ What am I doing wrong?
Iām having issues connecting to my skateboard. I have a bluetooth module on my board but i donāt think the app is able to find it. Thereās only a āUnknown deviceā which i canāt connect to.
Am i using the wrong Bluetooth module? This is what i have: https://eskating.eu/product/bluetooth-uart-module-for-electric-skateboards-ios-android-metr-app/
From the picture, it looks like a clone perhaps? It might not work with Android 8.
This link gives a pretty good idea of the original and the clone. In the image on eskating.eu there is only one capacitor, I think that the HM-10ās without the second are clones. but Iām definitely no expert.
SInce I want to update my phone to Android 8ā¦ Could you please link a correct module? Right now I am using a cheap HM10 clone, which is great!
