awsome app @Ackmaniac !! I have some problems though. since it was the fastest i bought a bluetooth HC-06 locally since i didnt want to wait for like a month for a hm-10 module. But i cannot connect to it, actually i dont really know if the app detects it at all. My phone’s bluetooth detection shows HC-06. I guess my questions is does this work with HC-06 module with 9600 baudrate? or do i need to get a HM-10 module. Thanks in advance
Guess you lifted the baord once and let them spin at full speed for a short time. That is neough to reach max speed for the app. It takes the wheels speed and not gps for max speed.
And at a average consumption of 17.520 Wh / km you can get max of 63.3 km. And 76% of that is around 48.1 km. And that would mean you need to drain the battery totally.
In reality you won’t even get that far with that consumption because you have losses here and there. And you would need to empty the battery completely. So i recommend to set only 85% of your theoretical Wh. So in your case 1110 * 0.85 = 944 Wh which would give you a range of around 40 km with 76 % battery left like in the picture.
And you have 9 inch tyres and a 8/48 ratio. Very unusual, can you give some more details.
And you battery settings are for sure not realistic. For your E-Golf batterys i don’t know exactly but i would recommend Li-Ion values:
100% - 4.2
90% - 4.07
80% - 4.02
70% - 3.94
60% - 3.86
50% - 3.79
40% - 3.715
30% - 3.635
20% - 3.525
10% - 3.435
0% - 3.26
Status Bar notofications now also have the speed as value. And it is possible to activate “Fast status notifications” in the settings so that each data update is also forwarded to the notifications. This should help that the you can see the actual speed on your smartwatch. I don’t have one so it would be great if you can give it a try and report if it works.
And the Board Info screen now shows the values for both motors together. Before it was only for one motor. So maybe it’s good to reset the value by doing a long click in the board info screen. Or at least you can reset one of the trip meters.
Your apps look incredible but I have an issue.
I am using an HC-05 and i’m able to connect to the vesc with the BLDC tool on my PC through bluetooth.
It is connected on my Master vesc with PPM+UART mode. (Uart in 9600bps)
When I try to use your app I can’t find my module in the list of device. I can find anything else but not it. (And it is not paired with something else)
Any idea why ?
Thanks
Crap, I can’t find any application which work with that module.
Thanks for the answer.
Would you share the code than I could adapt it ? (Couldn’t find it on your github )
