Invoice ID: ES-232
Been patiently waiting for this remote. Whats going on?
Invoice ID: ES-232
Ah it was in the spam.
Yep, this happens a lot
Thanks Wajdi, canāt wait to try it out, though iām a bit scared, as my board is very very powerful. Will have to detune for a bit
just went onto your website, logged on with my username and PW and then to My Orders. It shows that I donāt have any order history yet I did purchase on 14th March @ 20:20:57 GMT Paypal Transaction ID : 5NE830395T766474W
Is there a problem with the account history on your site? Hopefully I shouldnāt be too concerned, but could you please PM me with confirmation that you actually received my order. The money has definitely left my Paypal account !!
Cheers Tony
Hi Tony,
Your order was received, I replied to your email with details, let me know if you still have a question.
Hi @Wajdi,
The tracking code is still in āPre-Shipmentā status (since two days). Iāve called the transporter and they told me they donāt have the package yetā¦ iām pretty confusedā¦ When do you plan to send them ?
Thanks !
Packages were sent today. They have the new Photon v0.4 firmware with the following new features:
Confirmed, mine shows up monday, wahoo!
Recieved my remote.
Tried to power it on and am stuck with a blank white screen. what gives? Iāll try updating the firmware tonight
edit: cant find .4 firmware. ugh
Edit edit: Tried .3 ā¦ FW updatet worked, screen is blank. gonna have to send it back, unless I can fix it? PM sent.
I replied to your PM, sorry this is happening to you. I would be happy to take it back and replace it asap.
Thanks wadji for getting back to me quick
UPDATE: I was able to repair the remote myself. The pin header on the display to the main PCB needed a bit more flux and solder, and came right on. YAY
I also added a bit of double sided tape to the other end of the display to reduce vibration fatigue on the pin header. perhaps a suggestion for future remotes.
Iām having the same no throttle response issue you had. What did you do to fix it?
Okay, iām stuck again.
Setup: 12S Dual Vesc6 Ackmaniac 3.1 Firmware
Finally found pins for binding after messing with firmware.
Remote is on .4 now (verified in settings) Reciever is connected to bottom pins of VESC6 (top two adc pins left disconnected) baud rate set to 115200, all control modes removed, control mode set to uart and nunchuck set to āCurrentā
reciever has a solid orange light, nothing else controller shows no data.
i tried swapping the rx/tx pins on the cable, nothing. i tried the slave vesc6 with the same settings, nothing
do i have a bad receiver too? Iāve streamed data to my phone using uart and a bluetooth module, so i know the serial port works when set properly.
Itād be nice to have a reference what the LEDās mean, and an updated pinout on the website for the different receiver revisions.
thanks!
Ackmaniac Fw is unfortunately not supported You can use the latest official vesc firmware to get it working.
Ah. Ok. Will try this and report back.
itās not working for me, iām getting no data to the remote, and an solid orange led.
EDIT: Vesc6 works with the .91 firmware from vesc-project.com - I also looked through this thread again, and noticed this is posted earlier in the thread. Perhaps this info could be added to the main website for reference?
Steps for resolution:
Follow all original instructions for connecting the remote.
Swap the RX and TX pins on one side of the JST Connecttor using a tool (or a small knife or screwdriver) to lift the plastic retaining tabs.
Finally
So, I have another issue. I have an orange light when I plug the remote in, and while it was charged, it would say chargingā¦ butā¦ its not charging and now itās dead. what would cause it not to charge? I plugged it in overnight when I first got itā¦ once I fixed the screen, it only showed 9% charged, I figured it might be a big or somethingā¦ not sure where to look now
