Lol, I thought you were making custom hangers?
oh i am
doesnāt mean i donāt want one of these
My Raptor 2 just got delivered so Iāll have a board to ride while my Nimbus is down.
Iāll post pics when I get home my girl picked up the package they left it at my door no signature ā¦
Got the new front truck on I got her to 42mph on the night ride and sheās super smooth even on shitty roads. I have not installed the new enclosure because Iām waiting for the 6 shooters. I did buy a set of extra tires from another forum member @bimmer and they just arrived.
They are smaller than what I had imagined but this is not a bad thing, they also smell and feel like car tires. I canāt wait to try these wheels.
Btw whatās max tire PSI you can use on six shooters cause these tires say max 70psi if thatās true Iād be amazed lol
Iāve got a falcon 36 that Iām thinking of doing a similar build with. Since youāre still struggling with clearance with 107s, think it would be wise to do a 12s3p single stack and get a higher quality enclosure from another distributor? Just need to make sure the TB battery would fit length wise, I havenāt measured the flat part of the deck yet but I believe the wheelbase is 26.5ā.
Awesome build by the way!
I keep my 6 shooters, the same tires and tubes you have above, at 35-50 PSI. 35 if Im in the dirt, 50 on the street.
Clearance with 107 is not bad you just have to be careful with speed bumps the TB enclosure is super solid it takes abuse like a champ. I just wonāt putting on the new shiny enclosure till I get my new shiny wheels
Just sickā¦ I have a single 6374 12S3P and the power is more than enough for meā¦ The acceleration is impossible to handle without reducing the throttle curve (at least on my board - I got 76mm Wheels and a 1:2,5 gear ratio - maybe thats why).
Cool project tho
Damn 76mm thatās crazy, I tried my set up with 90mm wheels and I couldnāt full throttle itās too much torque.
I may have the same problem with the 6shooters cause Iāll be running 16/60 pullies I may have to make different pullies in the future
I now have 100mm MBS All Terrain which I will run at around 1:3 Ratioā¦ Aiming for more comfort and more clearance as my motor got a beating every here and there because I have a pretty low ride. I think with the MBS the acceleration and everything will be a lot more chilled
Just waiting for my 3D printer to design and print out the pulleys
Whatās your range with the 12s3p? Still worried about the clearance and would rather have a single stack battery.
Around 40km. Clearance is fine now with the All Terrains
it def has some flex. iām 180 lbs
Yea itās not a lot but itās enough to make the board more comfy, once @psychotiller ships my 6 shooters it should feel like riding on a cloud
Whatās the biggest battery I can fit on the evo considering I can do double stack batteries. I have a 12s4p and thereās alot of unused space under my deck. I was wondering if I could fit a 12s8p under there.
If you could double stackā¦
13s10pā¦ Or 130 cellsā¦
Wow thatās alot, I dont want to go 13s but then a 12s8p shouldnāt be an issue.
I was thinking of Making a quad 6374 board on pnumatics but my 12s4p wont cut it. So I want to double up and make an 8p
Yeah 96 cells shouldnāt be an issue fitting double stacked.
