I know what hit or miss means. I didn’t understand whether you refer to the flashing process or the Hm clone working with latest Android firmwares. The one yuu buy from vendors are 90% clones. There are clones that work with oroeo ecc even if not flashed that is the “hit” others and more common won’t work without flashing. If you need a clone module that works with Android ecc I will send you the link.
What’s the STL in the last pic? The filament guide/cable holder? I could use something like that
Looks sick not in person.
I’ve been working on this board for a local high school surf team.
Since my switchblade is already assembled it would be hard to check for sure. Let me take a peek.
Wheelbite I mean, I’m having hard time finding a good deck for my kit
I would say no, not without modifying the deck
I am going to cut this landyachtz switch eagle for mine
In general I hate the look of glass frit.
These last few ones of yours, especially the Haya, are turning me on to it a bit.
How is grip in the wet? How would you compare the grip to viscious grip tape? Does it wear down over time? Is it more functional aesthetic, or can an argument be made that it works better than coarse grip tape?
Personally I would think it would grip better than normal grip tape. Just because of the larger pieces that would jab into your shoes. However it’s know to ruin clothes and cut hands if not coated with enough epoxy on top
I got it here
Printed at 1.2mm layer hight and 20% infill
Thank you sir!
It’s a selfmade fiberglass enclosure which can house a double stack 10S5P and all necessary electronics.
If anyone was interested in what i was printing. It was my first try at a lithogram i need to buy white filanent for it to look really good but this came out nice in red.
And a skull bowl
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-2/88821/211?u=mynamesmatt @LunarKim are they sk3’s IN THE WHEEL!?
What kV are you trying?
They look like the old v1 carvon motors. Exactly the same I believe
Yes, that’s right. It is a used CarvOn V1 truck.
Filed for future photoshop endeavors
