Broski, it has absolutely nothing to do with the colors. They actually aren’t hex-shaped and they work SO WELL and don’t strip-out little grubscrews and whatnot
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/8295 @sayekim Have you got it running?? You could always route the trucks down the thickness of the trucks like someone has done lately to get a bit more clearance. Looking pretty slick though.
And mounting drop through. Hangers hitting the deck? This worked well for me
The rounded nubs do intrigue me. Alright I’ll give em a chance. Any difference between the not multi colored set other than being less than half the price?
Yeah it works but only bench tested and butt tested. Also one of the temp sensors is fried on the motor from the reverse order on the escape. Luckily that’s all that fried and hall sensor reading worked.
I did get over current fault with 120 motor amps. I was surprised about that since I have absolute max set to 130 and it actually recorded 147 before the fault which should not be possible right?
Settings are: motor 120 -60 batt 60 -30
I think I like this clearance but I won’t know for sure until I try the speed bumps in my street. Besides I like a low rider. I don’t think I’m going to try that routing. If I want more I’ll probably buy some 107’s or switch to the sixshooter’s when they arrive.
These are 97s?
Yeah I edited the post yes.
Those are hexagon. You don’t want hexagon ones. You want the “Wera Hex Plus” and accept no imitations.
They claim to be hex plus
Wera Hexagon 950 PKL/9 BM SB L-Key Set, BlackLaser, Ballpoint Hex Key, 9 Piece https://www.amazon.com/dp/B003KN3HOK/ref=cm_sw_r_cp_apa_i_5HSbCb7VRFJMG
Then they might be good
they are both sold by wera and one is half the price. surely they dont charge a premium for colors.
Yeah this has me worried also. I’d buy the more expensive ones
These are old ones but hex plus and single colour.
Inches or mm?
Those are metric if you zoom in real far
Hmm amazon has a colored set listed in imperial Wera 05022639001 L-key-Set for 950 SPKL/9 SZ imperial https://www.amazon.com/dp/B01H88FP24/ref=cm_sw_r_cp_apa_i_KWSbCbAETH7XN
And then the black and red set is listed in German metric. Only other difference I can tell.
It comes with some heat shrink in the packaging, you use that to shim it to fit calibers. Not ideal but it works.
no heat shrink was included with my order unfortunately
Bummer. I threw mine out when I opened it up, I didn’t really get what it was for haha.
I have never seen the black set. Maybe it just doesn’t have the sleeves?
They look the same minus the sleeves.
