I really dont know about the outside temperature increasing the range , because a lot of energy is loss due to the heat in the hub , if such high heat build inside the hub at 7 degree , i canât imagine what it will be at 20-25 degrees outside⌠maybe it does help the battery , i really dont know
I am pretty sure that Ride Tastic was expecting range improvement in relation with outside temperature and battery efficiency that is optimum when temperature is close to 20°C.
But +50 to +100% gap (range extension) are not standard values for 15° temperature inc.
Hahaha. Theyâve been singing the same song for over two years. They will tell you this no matter what dude. Youâll learn that very soon. Good luck.
I just got back from my range test. The conditions were perfect. Very good aspahlt and 24 degrees warm. Well what can I say I have ridden very conservatine, since many cyclists and children were on the track but see for yourself. I expected at least 30km and got 20km.
Avg. 27km/h or 16,7mph in rspec mode and range 20,39km
Also always kickpushed to start. My Weight is 88kg.
In addition, a large piece of my hub has fallen offâŚwill now contact Enertion (2 years platinum warranty).
I do not believe on it, a 20km ride and a weel is out of order!
I suppose it was not its first ride, did you do some ârange to liveâ estimation?
it will be interesting to follow this issue til final resolution, do you agree to log events here?
I forget what the electrical resistance is on these and the actual kv and could figure the km but for its size it shouldnât be getting hot or such inefficiency. Either would show up with these numbers revealing a bad km or else if thatâs good Iâm guessing itâs not showing up in the copper and instead iron losses from a bad magnetic circuit.
just continue to post events here to get a trace (log) of issues, fixes, resolution, or breaches.
your range expectation fit mine 30-35 km for cruising (to go to my office it requires 16kms oneway, and hopefully I can use bicycle path more than 95% of the way, last 5% are walk thru residential/parking/stairs).
WTF, to answer to your post Iâve logged in Enertion to check my order and I let you have a look on the screenshot below
2 set of Crossover wheels that are not existing anymore into their catalog.
If you have a look on their web site wheels are not referenced anymore.
I donât know how they are going to deliver as everything is already paid.
Thats no issue. They always take down stuff when they are not happy with the quality. You canât even order normal wheels at the moment because they are waiting for the new formula wheels that should fix the cracking issues. Well thats the reason why I am waiting 10 months now for my spare wheelsâŚ
They are trying⌠nobody wants these boards more without issues and in the hands of their customers than enertion. Its just obvious they have serious quality issues everywhere except the unity⌠and thats thanks to jeff, the one new guy at enertions product development that knows what he is doing. Bara has to fix the rest of the stuff and carl has to take the blame. I really donât envy these guys.
Yeah its insane. Even the cheapest chinese brand has better wheels. These thane formulas are well known. Its an absolute mystery to me how enertion is incapable to manufacture/buy decent wheels. I mean yes hub wheels are tricky and with that melting reactor of a motor nothing good will happen to any thane but still, amazing!
Thatâs what I noticed too, based on reports from people with the black motors.
i really like my raptor but the low range for a 12kg boardâŚthe high range has encouraged me to buy even of the heavy weight.
Well, I now have the 97mm wheels on it. Letâs see how long they last and when my spare wheels and motors will arrive. Otherwise I see only one possibility⌠TB DD
