Beautiful build. I’ve got similar parts but not happy with the deck I went with. I have a redember caldera to move across to I just need a new enclosure.
Will be coming back here for inspiration, just beautiful!
Evolve kindly sent me 2x Pulley covers with the 107s, but of coarse they only fit their tiny motors. Gave me the idea to make my own though for the 6374s.
This is most definitely Version 1, and is too good a fit with only 1mm clearance at best. You could argue that it will stop even more unwanted crud getting in there, but to me at least it looks wrong and needs around 3mm clearance to look best. I’ll take suggestions though…
Haha no probs ! Was just messing around with logos and stuff. Learned a lot this last few days.
Still need to tweak the design as it happens. The covers are fine for rear mounted motors, but after fitting to mine I’ve found that, for inward facing ones, I need to shave some height off as the covers catch the underside of deck (at full tilt).
LMAO! I know that feeling only too well. I love my 3D printer for that exact reason, the ability to try out designs in the real world without the cost and time it takes to get prototypes machined is priceless
Thanks! It’s all coming together this last week or so.
The mounts (and drive train for that matter) were all bought from Street Wing in UK. All good quality stuff, and good to know they all work and complement each other instead of having to ‘make things fit’ seeing as it’s my first eSK8 build project.
Can you print this in semi flexible filament? After having some solid risers then changing back to rubber ones the extra vibration killing from the soft risers is certainly noticeable.
Yeah I suppose I could. I had originally planned to use a 3mm one from my regular ramp boards (in tandem, like a sandwich) to act as a cushion, but I’ll look into different filaments once I’ve finalised the design. My main plan here is to have an extra section coming out with the wires, hugging the underside of the deck and routing directly into your enclosure, and thus hiding ALL the wires.
Just concentrating on the riser section first, then will extrude the cable ‘conduit’ to suit, getting the angles and curves right, once I’m happy the riser works OK.
well the Photon Remote part of this build has been dropped…
I ordered it on 14th March, albeit as a back order which I was fine with.
Had very little contact about the order, but put this down to ‘small business’ practices.
I’m a patient soul, and finally got an email out of the blue on 30th saying item was shipped. Shipped but not tracked… weird for a purchase of over $200
Sent emails asking for clarification but received no reply. Finally lost patience and thought the only way I’m going to rattle this cage is to open a Paypal Case, clearly stating in the case that I still wanted the remote, but I also need proper info and tracking details for a purchase like this.
6 minutes later I receive a full refund, again with no personal message or reason.
Make of this what you will, but I have to say I’m surprised considering the developer is a memeber on here and all experiences tend to get shared like this.
