not when you do it on your own machine
i get what youâre saying tho, I may end up threading it and just screwing it in to avoid that
A threaded in pivot nose will be a continuous source of failure and angst.
What exactly will fail, the screw-in pivot or the hanger around the pivot? I am not entirely sure whether an aluminium pivot extended from the hanger is that much better than a stainless steel (e.g. 17/4 PH) pviot with an M10-M12 thread? If you look at the graph, the shear capacity of an (e.g.) M10 bolt is within tens of kN.
(source: https://www.hi-tensilebolt.com.au/bolt-shear-capacity-metric/)Steel / SS / TI threaded into 6 or 7 series AL, constantly taking 2X the abuse the axles take eventually takes itâs toll on the Pivot. One of our team riders, would continually egg out the pivot / hanger interface of Fyre trucks making it loose in short order. He was not an abusive skater either. If you go that route, design will be extremely important to itâs success.and durability. I would make it unremovable.
Thanks for clarifying the issue! The pivot implementation on the Fyre trucks doesnât look that great and I can somewhat understand why the pivot will egg out over time. A longer stub (maybe twice as long), M10 thread and then glued in like an actual axle stub should make a difference.
(source: https://holyboardshop.com/media/catalog/product/l/i/liquid-fyre-trucks-cross-section_3.jpg)Are you really going to print Derekâs name upside down?
please inform me when itâll be upside down?
oohhhhhh shit
iâll go fix it now
At least you made a quick fix
I donât know why, but I find the writing close to the outside of the hanger looks better
I think it looks better too, but it would be covered by mounts and pulleys
I have an idea, maybe you would like it that way:
Where the red line is Sorry, only had axes to paint right now
Thats awesome, I like the curvature.
I wouldâve loved to change the tracking on the letters but cant do it in inventor
I think that is spot on, just the way you have it in the last pic.
I guess your opinions arethe ones that matter. I just think it could look better if the letters were spread apart a little bit more (tracking)
Let me please recommend you 2 small things:
By the way, I hope you will get on with that design, itâs interesting to see, someone cares about that
Your bushing seat looks very restrictive. You could adapt the Caliper II seat as a starting point and work in some suggestion / hints from Alphamail. Also, you could use DM instead of Derek.
This is a cross-section of the Aera K3 hanger:
I might be barking up the wrong tree here, but have you considered putting a horizontal bend in your hanger plate design, so that you would have a twin angle truck? Say a 5 degree bend on the hanger, mounted on a 50 degree baseplate, would result in 45 and 55 option truck. With this bend, if you flip the hangar you could have a lower (or higher) angle truck depending on which way the hanger was oriented. Maybe I am getting my nomenclature mixed up, but this idea might have some merit. This is what I mean.
A cheap way to get variable angle trucks!
The âbendâ would go along here:
Here are some sketches, I might be way off base here, but throwing Iâm this into the mix of ideas anyway.
Ordinary RKP truck with a flat hanger (e.g. 50 degrees):
Five degree bent hanger (resulting in a higher angle, e.g. 55 degrees):
Five degree bent hanger flipped 180 degrees (resulting in a lower angle e.g. 45 degrees)
What do you guys think?
