Hi Rod,
How are they battery wise compared to urethane? Do you have AT wheels to compare the battery usage to as well?
Cheers, Patrick
Hi Rod,
Cheers, Patrick
I remember, I never had that problem but Iâm not running them at the moment and havenât for awhile. The only time I ever had that issue was when it was below freezing.
i saw a video where someone accelerated rly hard and at top speed it expanded and wasnt rly attached to the rim anymore but these wheels are not made from PU like these 6" wheels. So i guess they have more integrity but i am no expert.
If the softness doesnât affect range too adversely it sounds like a nice ride.
I think the range will be affected, on the other hand you will have better grip. Itâs matter of what you are looking for. They look pretty decent for the price and if the damp vibration and bad roads, I am fine if the range is affected a bit. it means that they have a great grip compare to PU wheels. For sure these wheels are not made for pushing them
You said your wheels fit standard bearings.
How do you know which orders are in-shipping that require milling?
Are you reaching out to customers who will require milling, to let them know?
I ordered mine before you responded to the bearing size being a problem. Can I give my order number to figure out if they will work?
I order from Evon. Hopefully there are no issues with them. Iâll should be able to test them Friday
Why they weight so much? Isnât the core aluminum?
Got them today. The standard skate bearing doesnât fit. They core is a little unfinished. Iâll test them tomorrow. Iâm on the skull board hubs so I can check only the front ones.
The core looks horrible.
Damn⌠they look kinda wonky. I was interested in these. Real pictures are definitely changing my mind.
Christ! They look dreadful! Worse than the skullboard ones, and they are pretty poor
jesusâŚwell glad you volunteered. most important is the ride quality. Stoked to here back from you @DAddYE.
Well, thatâs an eye opener. These are atrocious.
Sorry, I was on vocation, just saw this nowâŚ
Turns out these donât look very good, thank you for checking in anyway
So, I drove them for 3/4 miles. They are pretty amazing. I live in SF in downtown some streets are awful. The front wheels absorbed every thing. Was a pleasure. However, this batch has the bearing issue, and the spacer for the bearings is a little short. On the vibration side, when you carve (so youâre on the wheel side) you still feel some minor vibrations. Not a big deal for me. They seems to roll slightly better and I think theyâre lighter than the A one because theyâre less wide.
Function over form. They may not look perfect but if they ride nice who cares. Hopefully the hub/bearing issues can be looked into.
how are they on topspeed? Do you have data on wh/m?
