To piggyback onto this, how does it compare in terms of range/comfort to abec 107’s(or other biggest urethane wheel you’ve used)?
Also do you go out to baeske8 rides? Would love a chance to see those wheels live in the wild
Also do you go out to baesk8 rides? Would love a chance to see them in action
Ive to do more miles, I’m on skull hubs and I’m within 13-14/wh mile.
This a slow run:
These wheels consume like 30-40% more than before (abec 90mm flywheel)
the increase is to be expected. well good to know, now i can plan around these wheels.
I wonder how these perform in the rain. I’ve had bad experience with urethane.
these are not urethane.
How are they on gravel/grass?
By that you mean you talked to them and they will fix it in the next batch or…? @Phoenix-liuqiu
They’re sending new ones
At their expense?
Of course lol
You never know
Stormesk8’s Black Friday 2018:Use “15off2018” to get 15% off for your order
Did you intentionally mounted those wheels like that? Those front wheels should be switched. The core is offset and longer overhang should be facing outside. Unless you want narrower profile.
i think he is from stormesk8 and posted a pic from someone else.
Just got 2 sets to EU… Somehow without customs . Guess that makes up for missing the discount.
Just need to wait for black Friday deals for large Kegel pulleys cause 110eur is a bit steep…
For my set, the standard bearing fit fine. One of the seat felt tiny bit loose but no rattle or play detected while riding. But, I also experienced the spacer they provide is short by 1mm or so. That used to rattle like crazy. One speed ring fixed those issues and now it rides perfect. Only downside I’ve seen is quite a significant reduction in range due to higher rolling resistance. Guess you can’t have both comfort/grip and efficiency. So far, these have been great on Boosted.
How is the core on these? Still ugly?
Look a bit better
