Yes! By using measuring tools
im using at 97mm 76a wheels 38t gearing
I have ordered a Loaded Vanguard Flex3 deck. Does anyone know the deckās thickness? I need that to buy the correct length bolts/nuts and threaded inserts.
Please verify the wiring.
BAT - >> BMS B -
BAT + >> I donāt see a separate B+ pad on BMS. Do I just connect the first balance wire to B+?
BMS P- >> Anti Sparkās B-
BMC C- >> charger port
Do I need a fuse for this setup?
Do I need a safety cutoff mechanism between the anti spark and BMS ?
I dont see why my ESC isnt powering on?
Even if im pressing the power button nothing happens. Do i need to connect the motor already? The battery is a 2 cell 7.4 V and the esc is this one i found on amazon: https://www.amazon.de/dp/B07PVJ18Q9/ref=cm_sw_r_wa_apa_i_AtR5CbC1XDGTKmay be to small of voltage to power the esc. Or it could be dead as those esc are pretty cheap
Approximately 1cm
So according to the Amazon listing, this esc only works with 24V/36V. You need a different batteryā¦
ok thanks:grinning:
Is there a cheap way to get the middle section of a DKP truck pair? It seems everyone has them (eLofty, Evolve, Backfire, Gullwing) but itās never sold as a single part
This looks like pretty much the best deal Iāve found for a 6s2p with BMS and charger all in one. Am I missing anything? Any place that has the same combo faster/in stock? Would like to pull the trigger in the next couple days.
I mean you can make it yourself a bit cheaper, $50 for cells $20 for BMS $20 for charger $10 for the rest, but thatās the easiest one
Because they realize they are shit and everyone should throw them away.
Who ever has a pair and thinks they are shit should send them to meā¦I just wanna play with them for fun
hello dose anyone know any good decks under 25 inches i would need to drill 19 holes in the board
A penny board?
yes i need it to hold 220
220 bundersnatches?
Go search for sites that sell decks and filter by length
Whatās a bundersnatch?
