I feel like unsoldering it could be dangerous, it’s supposed to be a sensitive thermal measurement part, PCB is just a brick of silicon and should therefore be more tolerant to tampering
What would be the recommendation for cutting? I can file it since it’s thin or use a Dremel with a fiber cutting wheel
I see. To my understanding (take it for what its worth), is that the sensitive part of the thermal probe is the top bit that is screwed into the heatsink.
For cutting, i would use a fine anything with low pressure when cutting (basically anything to reduce the strain on the PCB), but maybe someone else has a better reccomendation.
The thermally sensitive part is where it’s bolted to the heatsink. Desoldering the wires at their other end will be totally fine.
You can cut PCB with nippers, a fine tooth hack saw, or a dremel tool. Just be careful to avoid exposure to the fiberglass dust, and be aware that any non-abrasive tool will be dulled fairly quickly.
Whenever I see batteries there always flat packs, double stack or staggered. Are there any issues with building a pack with the cells standing upright ?
It makes the enclosure at least 65mm tall, street and hybrid boards just don’t have the clearance. It works for the Baja and its technically more space efficient but it’s also harder to implement flex into the pack and get the wires to sit in a neat bundle. It does make the welding more consistent though, all the nickle sits flat at each end
It would be okay if you use the side of the enclosure for strength instead of the deck so you could trim off some weight and get some bigger wheels
You have a bad bearing if the torque on the axle does not affect the rotation of the wheel. Without or indeed with a short spacer as you tighten the wheel the two inner races will compress and put pressure on the outer thereby causing friction and slowing down the rotation. Always better to ride with a larger spacer than a shorter and definitely don’t ride with no spacers.
