Don’t judge a book by its cover, single motor sk3 got me up a decent incline at 20mph
And this was a 10s2p battery
I still have my banshee hubs… sold the esc but its basically a modified ownboard kit
Anyone have any comments on the ownboard 105mm all terrain hubs?
What esc are you running it on now bud?
Im not. Traded it for belt drive. I did have flipsky dual tho
Speed wobble, at low speeds
Thanks for that input
So your entire deck is 23 inches or your WB?
Its the WB!!
I would contact him and double check which would be best Worst case you get the bigly and have to modify it
Thanks man
Single belt drive can be just dandy if it’s done correctly. A lot of mine are single belt. Look at my build thread, that’s the latest one
If I Currently get an error of "Status: Invalid serial port: " on the VESC tool, but if I upgrade the vesc tool, I get com3 limited, does that mean my usb port is broken?
How bad is it to mount the batteries and ESC above the rear trucks? Putting a sketchy 10s2p w/ BMS and dual ESC in a plastic Tupperware container with some foam insulation, and bolting it with the rear trucks hardware directly to the deck, maybe a rubber pad in between.
It’s a drop deck and I have short legs so I can’t easily put in underneath like usual or on top like a mountain board
Probably gonna hot glue the bolts and wires for waterproofing
No problem at all if you have room.
Sweet, just wanted to make sure the vibrations arn’t an issue or something like that
I have a layer of neoprene between the truck top and the box. Its my test rig. Seen some action has that old girl. Destroyed many a vesc. Well maybe that was mostly me but thats my story and I’m sticking to it.
