You donāt have to update it all the time like you would a computer. It is fine if you run it with the firmware that is on it now.
Carbon Fiber can also interrupt your signal to your controller as well if it is between the receiver and the controller
has the remote/receiver such a weak signal?
Nope as far as I know itās the farrady cage effect
Yep; doesnāt matter how strong the signal is. (within reasonā¦ at some point the heat from the eddy currents induced in the faraday cage will vaporize the cage itselfā¦ but youād need about 15 orders of magnitude of power to reach those levels)
Yepā¦ but not using an RC Receiverā¦
Make sure to use distilled water so thereās no leftover minerals or anything when you let it dry. (If you go the soap and water method)
also carbon fibre is conductive , so make sure any edges are coverd or your batteries will short etc
Whatās the water for man
Cleaning PCBās if they get excessively grimey.
Aw thanks man , at first , I was thinking that that whould counter react the Faraday effect , my mind was like how ???
If you didnāt know, you can follow the reply chain by clicking the little back arrow on my comment on the right corner
Yea man , IM not that much of the noob
Where could I find the bearing spacers for 12mm ? Iām using matrix trucks(old version) & trying to have a spacer in between my bearings. I tried looking for it but I donāt think Iām writing the correct way to look for it. Iām writing 10mm x 10mm x 12mm & what Iām looking for is not coming up
I wouldnāt worry too much. Those little lipos puff pretty easily.
Every single time I go to aluminum spacers .com I end up leaving again because they have a hot steamy love affair with Freedom Units and they seem to not be getting help for their addiction.
One good place to find spacers is the bearings themselves ā the inner raceway is the perfect size, only question is it the correct width?
Thatās a good thought hmmm Have too think about this one Using the MBS rockstar hubs
