So first get a pair of needle nose pliers and insert them into the C adapterās like this
Then twist them so itās like this, this should now fit on the truck. If it doesnāt then just shove the pliers further down at the first step
On the clamp, the screw has two sides it can go into, you want to insert the screw into the threaded side first
Like this
Then when your near filling the gap get a piece of strong metal (I use the metal ring thing from the front of my dicky pulley) then tighten the screw until it bends the metal out
Then just put it in the truck and remove the screw and youāre all good, just when using that extra piece of metal make sure it isnāt obstructing the part where the truck goes into
This is my method for getting these mounts on. Its yet to fail me
If I did the calculations correct and looked at the right meepo battery the meepo battery comes out to be 291.6 wh which is more than the boosted. The meepo is a 10s battery. Iām not sure what the boosted battery is usually those batteries from those companies are not interchangeable as the esc is set to specific settings and are not changeable.
Iāve seen random dual belt motor kits from the diy site or even on eBay. All I would need is a dual belt drive esc and that kit, connect it to a board and battery and am pretty much set up?
