And they come in a variety of kv so you can get one for pretty much any build
Seems like a great choice, just have to doublecheck with the designer of the motormount if it will fit
Which KV should I choose for double setup with 12S pack, 8 inch wheel with 72t and 15t pulleys on the motor?
Thanks guys!
Depents on your max speed you want to reach. You can calculate that by your own https://calc.3dservisas.eu/?Pc8xD8IgEAXg_8JsDBRo1RVNpxoSE7srQ00kJelo_O-997Bu3z2O4_ioR5jUSb1fZVY7Ka5S2H0nXsJNbCwZhY4KaNBaszijMr4aPU3NOdMIC2a0ADp9vVci0oaKmzjKehJhS_4HPSeeUxfRQZN3XHdwDr9JmWt3zOIMOxI_qO_nwBjNaVy4NeLUD9tvUj9iBSye8NpRq-8K
And the @idea motor mounts are a good choice
Thanks for the calculator!! Before I had to manually calcualte all Is the āmin speedā value in the calc the speed at lowest battery voltage? Iām aiming for 50kmh top speed but also not too much lower even when 12S battery is low. 4400W from the 192kv version is quite tempting xD
Is there any difference between V-belts Guys and V-belts Supply Where do you guys recommend?
Hey man, I live in hb and have an electric skateboard ā¦itās brand new. Iāve had it for a couple of monthsā¦I just couldnāt get it to charge or turn on. Haha I was wondering if you know anybody who can help me out. Thank you
Nope, same belts. I usually use v belt guys as they send me coupons.
There also a hell of a lot cheaper
Are these wires fine to use?
Of courseā¦ what do u want to do with them?
If itās for doing anti spark or battery leads I would do 10 gauge or 12 gauge.
If itās anything thatās going to be on a board - the answer should be no. You donāt want solid core wire on anything with as many vibrations as an esk8.
In general try to use a high temp resistant, high thread count wire. Standard wire will have 30-40 strands inside, the high quality will have close to 1000 strands. Smaller gauges of wire like motor sensor wires donāt have many HQ options.
Curious if anyone has any tips on cable routing/cable protection? My wires arenāt very long and Iāve already drilled the holes for the Vesc enclosure on the board.
Donāt run the cables over the truck, run them underneath to get more slack. Like this
Whatās this here? Also, I dig the cable loops youāve got on there to keep them out of the way!
Thatās a plastic cover to keep the cables close to the deck and prevent them from touching the motor
How do you have it attached?
Its attached with wood screws.
