Thanks! Iāll let it go and hopefully this wonāt be my last post.
edit: Itās bestech D140
The d140 specs
all packs are at 4.21V and sometime goes up to 4.22V while B1 is still at 4.17
If you can monitor it than have a look that they donāt charge over 4.25v. If I charge my lipos the first cell usually higher in voltage too till reached 4.25v than goes down to 4.2v till all cells are 4.2v
whole pack now at 42.0V volts and B1 is on the edge of 4.17V and 4.18V. The other groups rise to 4.22V sometimes.
This is the first charge with my new 4amp charger
Charger just turned green and I took it out. Most of the packs are at 4.21V or even 4.22V while B1 is still at 4.17V. Does the BMS still balance while the charger is not connected?
Not sure how it is with the d140. Why not let the charger attached for a while?
PS: as long as the cells not more than 0.1v our of each other I wouldnāt worry so much. They will probably anyhow discharge slightly different.
So the charger dosenāt charge the battery anymore. All packs are now at 4.21V unless B1 that is still at 4.17V.
Do you think itās save to plug the charger in again and let it go?
Lipos or li ion? If its li ion, Iām willing to bet a single cell in b1 is dying.
Itās li-ion 10s6p samsung 30q. This is the second charge so hopefully itās not already dying.
Are you able to check each individual cell?
Not really. That would mean I have to tear all the heatshrink and welds off. I can only check the parallel groupsā¦
Leave it @ what its @ right now. Maybe set your cutoffs a volt higher for saftey, but go riding. Running the pack down a little. A few volts worth. Charge it again and see what happens.
Iām almost positive though you have a dying cell. Did you buy (who from) or build the pack?
All parallel packs are now at 4.21V unless one that is 4.2V. B1 is still at 4.17V.
I bought the cells from nkon and made the pack myself. I had no problems with the first charge but that was also with another charger
edit: But do you think it would be safe to plug the charger in again?
Have you tried that charger again?
No, but I can do it.
Go ride it if anything. If youāre going to plug the charger in, might as well make it useful lol. Sitting there plugging and unplugging isnāt doing major harm but you are taking away from the life of components. Go ride it.
Plugged in my old charger and it also shows green. Will let it sit for a few minutes and monitor each group
While charging the pack all groups charged completely fine. They were all at the same volts. Could it still mean a dead cell?
So all packs are balanced the same? Go ride it! Run em down. Come back and check your groups. If theyāre balanced, cool. If not, you have internal problems.
So for this instance weāre going to say that your pack is still balanced after riding. Plug in the charger that wouldnāt balance completely. If it throws that pack lower, plug the other charger in. If that charger balances them out, then you know its that charger thatās messed up.
