Badass! Those things look rock solid.
Is it very noticeable to be pivoting from the axle height verses within the baseplate? OR closer to the deck? I would think the tilting at the axle would create a tipping over sensation due to side to side movement of the deck over the pivot. Iâm curious to feel these thingsâŚ
I think probably its largely just visual. Since this design is all skeletonized you can make out the movement a bit more.
Its going to be rakeless, so the tippyness feeling is probably going to by typical of a rakeless truck. The height of the deck from the roll axis may be a little bit taller ( but maybe not, canât tell for sure ), but it wonât be more than a similarly tall RKP.
I have them set up split so the front turns more than the rear based on the base plate pick up points. They are in theory rakeless but they are much more lively than any rakeless truck I have ever ridden.
What duro bushings are you running Brad, 93a Krank?
I am running modified (opened ID to .500") KranK 90a Chubbys up front and KranK 93a Chubbys in the rear
ah, yeah I didnât even think of that Moeâs axleâs are bigger than a kingpin.
It wouldnât be a problem or anything if I made a copy/model of these things to show off and make a video of would it?
I mean, youâre not keeping these on the down low or anything?
Knock your socks offâŚ
I am not sure if you understand what it took @MoeStooge to get here and please excuse me if I am stepping into something that I shouldnât.
If you have 6 months or more to work on this then yes, knock your socks off. It is not an easy or intuitive design to work with at least for me. Personally I would try to convince @MoeStooge to sell you a set and when they are shown of, be sure to let them know whoâs mind they came fromâŚMr Biggs
Iâm not expecting to make anything ridable, just something that moves in the same way so that I can talk about it. Very dumbed down, oversimplified, not even with any bushings or anything.
Of course Iâd share where the design came from, probably link to this thread or something.
why is motor is disconnected, and why only 3 isnât suppose to be 6 wire? never mind, I see it underneath it
How is the testing going? I want to see some video of this thing rollin!
DH 3-link truck with 4200w single motor and allows 70mm wheels with an idler gear. Trucks are 50/45 adjustable to 40/35. Plenty of power to pull a hill. Swing away the motor and gravity bomb the hill. Just a mock up, should be testing tomorrow. ! ! !
Making headway on the V-3 raceboard for the World Cup wild card race on Sept 23rd in San Diego. Will be a front driver. ! IMG_20180908_183131823|690x388 thx again @Alphamail for the amazing bushing options.
Looking good MoeBro Are you going to run the (your) narrower âstreetâ wheels or are they just for mock up?
Options open. On the abrasive epoxy surface the Colorado track the harder street wheel would have performed better. We will see what wheel is better for the K-1speed kart track that will host World Cup.
