I have dual VESCs and I turned off the CAN forwarding, I have honestly tried lots of things, even redownloading the app. its still not responding past the screenshots I posted earlier.
Is there something I need to turn on in the VESC setup or something I am missing here?
Yesterday i had my first ride with the app.
I recorded the full trip and looked up the data after on the website linked in the mail.
Can somebody explain why the max values in the app don’t fit to the max values shown on the website.
For example max speed in the app 39kmh (sounds right).
On the website 68,5kmh (sounds a bit much).
One more thing I find a bit confusing.
In the app settings you define your pole pairs.
But the app shows only right values if to enter the single pole number (in my case 14poles, 7 pole pairs, but functioning right only with settings 14)
I think this should be changed from „pole pairs“ to just „poles“.
Does your app see the Bluetooth module?
You can check it in the settings.
I had the problem that the Bluetooth module was used by an other app and that´s why I couldn´t connect.
Hi pat,
Yes, the answer it’s always the same.
You have to check your bt module have the same baudrate than your vesc. In your setup we can see the vesc is using 9600. That means your bt module use another speed. The default baudrate vary from the different brand/model of bt module.
I can see two solution:
You connect with serial connection to your bt module using your computer , and you change the baudrate to 9600. Ask google for a tuto.
You change the vesc serial speed to other default bt module speed (ex: 38400). Save to vesc and try again.
Hi @emmaanuel - I just bought the app and after some digging I finally made it to discover my Bluetooth module but unfortunately I am getting : “UNSUPPORTED VERSION” - I have 3.39 Firmware.
Love the app, keep up the good work over there! Quick question… will your firmware I have on my VESC work with the firefly remote that people build on here? Having someone make me one and wasn’t sure it would be compatible and prefer your firmware and VESC tool over that remote. LMK when you can and thanks so much!
