Someone contact Sean’s fiance and let her know he offered up her nipples on the esk8 altar before they were even married. Risky move.
Done…
Wish there was a mega heart button haha
Just so you know dude. I love you. I’m really glad your on the Enertion team. You’ve done things that they didn’t do in a year of begging them to. Open source. For real!
Edit- Duh. And the Unity. Which is amazing. That goes without saying.
Unity has 3 uart port, ima go steal some code now
Support for UNITY stock BLE module is not planned at the moment. We discussed this option with Enertion and I am happy we tried. Unfortunately timeframes and resources were constrained and we couldn’t come up with an agreement.
What we are working on with @hexakopter is adapting Metr Pro firmware and Metr App to the changes in UNITY code and making sure it all works well. We also have another project in the works, a smaller Metr Pro variant that can be fitted inside UNITY and replace the stock module.
!!! Exciting! This is great to hear! Can’t wait to pick one up
THIS is awesome. Great to hear that.
Thanks for the spoiler!
How long till you will have the current units up and running with the unity? I have one board desperately waiting for you
Soon™️
Such a wise move…
If Enertion can’t agree a deal you just make a replacement that any DIYer can change out. Bravo
Where Can I find the other another spot to connect Metr pro. I installed the unity today.
The code stealing was sarcasm, was the other part also sarcasm? Did I use the term uart wrong? In drone boards it’s actually quite common.
There’s 2 ports that are not really accessible, under the cover on the 2X7 connector.
Same boat… i’m looking to find a solution to plug my photon receiver and the metr module on my unity. Please help
Picture by @pjotr47
It won’t be click-in and power on… I think this will require fine soldering.
@rpasichnyk You have an estimated timeline for the custom smaller module? I might want to change my order for that new module. Soldering that would be much easier then wires. transac nr: 0XH86601T4183640N
Can we just stick in those pointy wires in the 2x7 connector? Not enough space though in most casings. It will be fiddly if you’re not used to it.
Don’t expect it in the next weeks. It will take some time to test, program and source parts. I am in contact with @Deodand about getting a damaged Unity from the final production batch to see if the new smaller Metr Pro module would fit and work. Right now we don’t have a final production Unity to test the module and there are also other factors that could delay ETA. We will let you know when we could estimate a date.
@jadatmag Your module would be shipped today, but we can also hold it. Please let us know ASAP if you want to cancel the order. Its not a clean and nice option, but when you cut a hole in the orange silicone case of the Unity and build an adapter cable it could actually work. But I wouldn’t recommend that “dirty hack” and see problems with loose connections.
Please hold it off for me.
Can I be be the first one to receive the special module?
I put you on the list that you want to buy one.
Any thoughts on what’s the best way to reattach antenna to the pcb?
Buy a new one, plug n play.
I think there are links in this thread. The antennas should be the same as wifi router ones
