U have to resolder the 0402 capacitor next to the antenna plug into the other direction to “activate” the PCB Antenna
0804 is for beginners
0603 is for intermediate
0402 is for ABSOLUTE PROS with microscope
(its the SMD size of the components in 0.1mm)
Bjork3n
January 4, 2019, 5:04pm
611
Just tried connect via tcp , works like a charm!
Im so glad that i never have to remove my enclousure again to fix with the settings with vesc tool!
Amazing, just amazing! :
After years of hearing about this awesome module, I went ahead and purchase 2 for my builds.
Hope you guys could help me figuring out how to connect pair the module.
I tried to pair using PIN 0000 and 1234 but neither worked, if there a default PIN I should use?
There should be a sticker on every module
Damn, I’ll have to crack open the enclosure. Thanks man!
Update: I was able to connect perfectly. Thanks for the input
I’m having an issue with my module> I try to connect via TCP and all 3 lights come on and are solid. The module then disconnects. I don’t get any error or fault notifications though.
Is there any chance of having the VESC report demanded throttle to the app?
Did the update that supported the unity but I still don’t get telemetry.
I think he’s still working on it. I thank that update was for the phone app itself
sofu
January 9, 2019, 10:15pm
619
I get telemetry on the unity… Make sure you have your baud rates and uart settings correct
Ahhh I didn’t think of the baud rate , let me try that out now
Idk even know what that is. I’ll have to check again.
Where is this setting? I can’t find it
Under UART tab in the Focbox tool
Changed baudrate to 9600 bps and I’m getting telemetry thanks @sofu @rpasichnyk
Alright will try when I get home.
UNITY support is now live We pushed it about a week ago!
DAddYE
January 11, 2019, 5:09am
626
Is it possible to automatically start the app and record a session when I turn on my board?
there is an option which you can enable to automatically start and record sessions based on speed.
DAddYE
January 11, 2019, 1:27pm
628
But the app have to be open
