So my coworker ordered all the parts and asked me to build for him. 3 months to order parts, 26 hours to assemble. So this will be a quick just pics thread…
Main things…
@Eboosted enclosures
The rest…well pics
I saw another build with separate enclosures and they used braided copper wires then put grip tape over it to look like there is nothing connecting it. That is also what they did with the boosted board.
The wires on the BMS are the balance port, -C coming from the negative of the charge plug, and -B being the negative of the battery. The white wires are the thermal shut down sensor of the BMS.
You are building the exact same build as me man! I have the enclosures from @Eboosted already. Glad to see there is enough room in the battery compartment for the BMS!
yeah I do actually @Deckoz - how does she ride? Im expecting boosted but powerful! How did you secure the wire between enclosures? I am going to route a channel on top I think
On my vanguard I routed the board and wiress on top and covered with grip tape.
His wire is taped for now as the picture above as we are waiting on a wire channel.
The board is powerful, 31mph. But I’m jaded by the 107s on mine…so the 83mm wheels feel a bit rough. All in all it rides great and is super smooth, setup as Sensored FOC.
I also waited very long time for this BMS to arrive from China. But eventually it did arrive. (Then it burned. Then I ordered a new one, which arrived quicker, meaning less than a month.)
Did you put male XT90 as the main battery connector? Might be a little dangerous. You should tell your friend not to insert a screwdriver there. Why not female?
