60A, good for a couple Focbox’s but not enough for a couple HW 6 esc’s, def. not enough for a couple big rc esc’s look great! I bet at 60A you will get no failure…
Nothing personal dude, I’m sure 60A will cover most of the current market. I’m sure it is plenty for you. But it is not enough for me. I know you don’t understand hence your comment…
Sorry I can‘t follow you. I have set both my Mot. max at 100A, so at low duty C. It pushes much more Amps, but the current decreases exponentially after gaining speed.
I am just wondering if you/ someone else can show data proving that they push high amps continuously, nothing else.
Maybe Jens? I think @Nowind uses a Metr Module
@bevilacqua If people want equipment that runs more than 60A continuous, it doesn’t even matter how many amps they are running. That’s the equipment they want. End of story. I happen to want higher ratings than that as well. I’d rather get something rated for triple what I need – then have zero worries if it will fail under ANY amount of abuse, now or in the future, and even when it’s old and worn-out. Because it’s not worth being late to work over.
But frankly, why isn’t even relevant. If that’s what he wants, you arguing with him is silly.
