I understand that you are doubtful about high priced bearings I am too. Thus why I have always use zealous they run smooth and have built in spaces and speed rings and are cheap. When I originally started looking at these the now president of the company was the person who I was speaking with when he was an engineer a few years ago when he was with a different bearing coming one that did German manufactured bearings. I was able to get @b264 silicon nitride bearings for less than probably any other hybrid bearings.
Hey. If you want to have a second set out there. I usually ride out in the rain and crap thatās always on the streets of Atlanta.
These actually came straight from the manufacturer.
So not possible to get these right now?
Love a wack at a 10mm variant for the surfrodz guys. Iād be all over these. Im like b264 in tge sense i donāt drive. My board gets me to work. And i live im pnw. It rains. Alot. True testing is gonna take forever lol.
They would just be dropp shipped from the manufacturer. That is what I did with @b264 transferred funds for the bearing through PayPal
What are the measurements for surfrodz bearings and Iāll check.
Itās a normal skate bearing but instead of 8 mm inner diameter itās 10mm
What I saw was a 10mm x 22mm x 6mm so itās a mm thinner than the 608 they are more expensive however.
If the 1mm wider are cheaper, The width isnāt important seeing we still use same wheels pullys. Just inner diameter is different for us. I donāt even run surfrodz bearings.
you want a bearing that lasts then go for a scooter bearing. No other discipline puts as much pressure on a bearing period. Hard side ways hits and massive impacts. These are 608 size with a 10mm shaft.
Go to a scooter store and buy specific scooter bearings. Forget ceramic. They are good initially then fail with catastrophic results. Bad steel just keep rolling, bad ceramic disintegrate.
Ceramic is fine as long as you donāt assume skaters are using full ceramic bearings. Hybrid ceramics are what you want, just the balls. Slather them with a good amount of āball butterā and they last as long or longer than the steel variant. Also if you are paying over $30 for a set of ceramics you are wasting your money.
Ball butter mmmmm. stop it!
LoL since I have motors, it doesnāt matter
Me too, but if they do end up being great, we wonāt know for sure until after winter is over
Built-in spacers only make the bearings less useful, not more useful. Keep the bearings as bearings and the spacers as spacers.
These bearings are not the type for downhill longboarding but fine for motor powered applications. You will rarely change these types of bearings for maintenance.
Iām confused as to what world a built in spacer is less useful? We appreciate what youāre doing but itās kind of like you are trying to reinvent the wheel.
I assume he means for pulleys that have built in bearings. Zealous have spacers AND speed rings built in. The speed ring spacing (.5mm) probably interferes with using pulley bearings.
However Iāve found that itās much easier to just stack 3 zealous bearings and have one act as the pulley bearing. Of course itās gotta be designed around that bearing shape. But it should be standard with other integrated spacer bearings.
I mean like Zealous bearings for example where the spacer is built-in. Thatās less useful, not more. Because now I have to work around that if I want to do anything except what everyone else does with them. Isnāt this a DIY forum? Last I checked, itās not apple.ācom
Sure it may save 3 seconds in installation, but then it eliminates most things you can use it for, aside from a āstandard, traditionalā skateboard wheel setup. It makes it harder to innovate. Also what if I need 0.2mm speed rings instead of 1.0mm speedrings? Now my bearings have to be changed? What if I want bearings in my pulley? All of these things now those wonāt work for, and all to gain 3 seconds. Thatās a terrible deal. There is no ROI on integrated spacers and it can stifle innovation because itās one more obstacle to work around for nearly no gain.
