around Easter I think. I already have booked a flight home to help my father with the production. So mid-end 04.2019
Otherwise I plan to stock some boards and open an online shop in some weeks.
You got me cabrón. Filled.
Where you from Madrid?
No. Galicia
Ahh, my memory has tricked me once again. Im flying first a couple of days to MAD to visit some friends, maybe I can meet up Hunter @monkey32.
En otra ocasión! Y gracias
If you visit Galicia let me know. Beers are on me.
@bevilacqua & @rojitor Let me know when you kids are around Madrid. I am always down for a round of brews.
Even with thicc risers and 6.5in tires I’m still getting wheelbite, unfortunately. And I really hoped the Fatboy 240mm trucks would be wide enough. Only options are to go 6in tires or find and even wider truck.
Be careful. Say his name 3x and he’ll appear!
Have you looked into mountain board trucks, they are usually wider but will need a 30 degree riser
You could try this 2€ solution maybe … (Cheap piece of steel for construction at your local DIY store )
Before to spend 2 or 4€ with the front, you could try to find the perfect size (L x W) with of piece of wood ^^ :
If I’m gonna do brackets I’m probably gonna go gbombs, but I’m trying to explore alternatives before throwing the towel and getting brackets.
This one looks good too
What are those? Link?
https://www.electric-skateboard.builders/t/exile-ldp-mud-flaps-are-they-any-good/81937/5
Exile make another option
@neiru37 The Haggy trucks are pretty long, not sure of the exact length from axle to axle. Maybe @riverside.rider can chime in with the dimensions. Only problem next if its long enough, is that you need to use a different gearbox because of the truck profile difference.
i have the same idea. btw did you actually ride with those brackets? how thick are they? how does it feel? Elaborate.
