they are, I have a set
There are even smallerā¦ this is a 100mm (4 inches)ā¦
ā¦no pneumy thou.
https://pt.aliexpress.com/item/5-polegada-de-pneus-para-scooter-el-trico-de-fibra-de-Carbono
Not really pneumatics ehehe I think we should be happy with 6 shooters and haggyboard plus 6x2 tires and 6.3 tires from TB that should for evolve, mbs and trampa hubs.
ā¦a gummie 5.5 inches
If would fit MBS or trampa, I would test
I was thinking to order a set just to test 5 inch pneumatics. https://www.aliexpress.com/item/5X1-Pneumatic-Tire-With-Inner-Tube-Electric-Vehicle-5x1-tires-Wheel-Metal-Hub-5-Inch/32880618577.html?spm=2114.11010108.06001.34.5975649bia06ju&gps-id=pcJustForYou&scm=1007.13562.109986.0&scm_id=1007.13562.109986.0&scm-url=1007.13562.109986.0&pvid=0b75d6fe-070b-4761-b1d3-a39fd457a5c6
In those scooters they are using solid wheels @mmaner do you use them? For sure they wobble right?
ā¦Gummies from all sizes
i used them for a bit, they arenāt too wobbly, they just didnāt really feel great to me.
has anyone used these sleeves?
I would buy those from you but shipping probably will kill it
Sent inquiry (for the 125mm x 50mm tires) direct to the wheel factory, boys! (now lets pray)
Hahahaha they donāt answer
First was thru Alibaba. This one was directly thru their representativeā¦ lets see what happen. Hope is the last thing you lose.
@pixelsilva and @LukePL I have spoken to them about the tyre already, which is why they arent responding to you guys more than likely.
They donāt have the mould for that tyre anymore and are not prepared to reproduce it for any less than 2000 wheels. I had originally paid for 40 test tyres and shipping through a contact in China but when the order was relayed to the factory floor they declined it because they could not find the mould.
Edit: There is a second supplier directly on Alibaba, I spoke to them for a month but in the end:
ā¦but when the order was relayed to the factory floor they declined it because they could not find the mould.
Guess who was sure of that?
Thanks a lot for info! They could just wrote that or even put this 2000 MOQ in Alibaba. I have also contacted other factories but all of them want to make big tires because there are the money. I really want a small tire and some DD. Iām afraid that 6 inch is to big.
I would be surprised to see then selling those tires with EVOLVE logo
