After doing the Motor Setup Wizard for the first time and selecting Hall sensors from the dropdown it says in the FOC tab that Sensormode 1 = Hall Sensor and Sensor Mode 2 = Sensorless.
So I think it only sets Hall sensors for one motor in the wizard. I replicated it 2 times and just went on to do the motor detection in the FOC tab.
Great work by the way!
EDIT: Oh maybe it’s just me:
It says Bad Foc Hall detection result received in the Hall Sensors tab
Anyone having issues connecting over Bluetooth? I’m on PC, the UI connects fine over USB. My laptop connects to the Unity Bluetooth, but the UI just keeps saying scanning. Is there a step I’m missing?
Not quite sure who could update this but the telemetry on my Photon remote doesn’t work in combination with the Unity. I’ll post in the Photon topic if this is the wrong place
To fix the Bluetooth function, what exactly do I need to copy/paste into the terminal to fix this? Is it the whole code string noted above or just specific lines.
Sorry…Never played with this code stuff before and I dont want to brick my unity. Any help would be appreciated!
They code outlined above is for how the UNITY does UART so that people like @rpasichnyk and @Wajdi can make the unity compatible with their applications.
From what I can see unless the blizart remote has a reciever , you cannot use it with any vesc.
My laptop connects to the BT, however it does not let me connect to the board through the unity UI. Only “Connect USB” is available. The “Connect Bluetooth” button is greyed out.
