No heart for you
just pissing in your cereal
Not possible sorry.
Is traction control already enabled with Unity. The motors seem to spin at different speeds, how do I sync the erpm of the motors like on focbox and vesc tools of past?
Nah that feature will be in an upcoming FW update, currently it isn’t implemented.
Is there any chance to use the BLUETOOTH module with METR? I need the UART port for my FeatherRemote and want to use METR at the same time…
10 charchar
Is it possible to remove the power switch? I want it to power on as soon as I power the battery.
Does the 5v JST port need to be enabled? I just got my unity and have a 5v ESC fan that I want to power from it, but I’m not getting any voltage.
Answered a few days ago, looks like you just short the switch.
No… it’s on all the time. U mean the UART? Port?
I have an issue with the JST 2 pin on the bottom right of the Unity, I connected it to my battery indicator and it does not seem to turn on when everything else is.
Did you wire it correctly? The jst cable that I have puts the black cable on the voltage pin (according to the diagram that came in the unity’s box)… I though it was weird
Okay my mistake, i had the wires swapped, swapped it back and it works now! Thanks!
So are us iPhone people just waiting for an app to operate/view the unity through? It would be really sweet right now to be able to view my battery voltage!
Has anyone successfully got the unity working with a firefly remote? I believe PPM is working fine for me but I understand there is a change in the UART protocol, and maybe that is what is preventing getting good telemetry data. Does that mean I should make a change to the receiver code somewhere?
Mine works for controlling the board (really well I might add) but I’m not getting telemetry. Pretty sure the baud rates match (11520).
I also tried switching rx and tx wires on the receiver. I either get nothing, or garbage data. I have 5V, GND and PPM plugged into the servo port then just the rx and tx wires wired on a jst plug which is plugged into the comm port of the unity.
Line 166 here is the order of the new values output:
I meant to make a new packet with dual motor data and leave the legacy packet there but I kind of forgot to finish that before launch. If you peak at line 1077 you can see I have the new packet created I just never reverted the old packet structure.
If I understand correctly, this breaks all 3rd party stuff that attaches to UART?
The natural followup question: can you revert to legacy packet, and push out a new build?
Honestly, the get_values packet has changed quite a few times if I’m not mistaken. I think a lot of stuff already has support for multiple get_values formats so it’s a matter of adding unity support.
I could make that change but I’m not sure on it. I don’t want someone feeling like the values part works with a legacy tool then writing config values from a non-compatible app and bugging their setup. Some of the vesc uart stuff isn’t terribly reliable.
But yeah if enough people want it I’ll change it.
Firefly remote users salute you o7
