Theres no good reason, why these parts can’t be built into a 3d printed trigger style remote. Someone just needs to model it.
Do it
10char
Yeah… Trigger style would be so nice much more control on a MTB
If someone made one. i ll create a PCB for it!
I think you just need to flip the wheelknob magnets. Tath way you would reverse the hall-effect
Short update! I started to assemble the first batch!
How do I know I am one of the first 10?
U are in the first 10! Payment done? I am currently at 8 orders.
Just one question, the pcb size of the advanced receiver is the same than the basic receiver? Just not populated with all components? Or the basic is smaller?
Smaller… less then the half size of the advanced PCB.
Tomorrow i hope i have time to make pictures from the small PCB.
Looks great, didn’t realize it would be so high priced. Is the set down for 10s only?
If so, I might just get a basic and call it a day. I have done the tail lights using arduinos before and it works well. Just take in the pwm and if past a certain value, make the lights brighter. And once it falls down below a certain value, the light dim again. Pretty simple code.
PM’d in the hopes that an advanced version is still available
Woo Hooo ! Hopefully one of those is mine
I ll double check later if a 12s is possible…
MAYBE u/me have just du exchange an condensator.
I’ve just realised that this is not going to work for my 12s board…
No problem guys! U are in the first batch where is a little bit space for changes.
Looks like i can upgrade some parts for 12s. I have to change at least the diode and one capacitor. I try to organize a board with 12s to test it. I run only on 10s, But i look optimistic!
If you’re changing stuff, go to 13s.
Agreed with this, might as well give yourself the headroom
I will need mine for 12s too pleeeaaase
