Here is the kit for TB218 hanger. The motor can be mounted inside and outside
That is so cool well done !!
Not the same pattern as supastar?
Gear mounting and ET difference from normal wheel hubs.
Are you only using 3 screws to mount the motor?
Yes
10char
TorqueBoards variant is up for sale:
http://www.electric-skateboard.builders/t/selling-easter-sale-fatboy-mini-drive-train-1-3-for-torqueboards-218mm-trucks/50784 https://shop.3dservisas.eu/products/fatboy-mini-drive-train-1-3-for-torqueboards-218mm-trucks
Manuals were added
Trampa Version:
TB218 Version:
Hi, waiting for the wheels to arrive should be in around 10 days… Because normal shipping is like half price of wheels using USPS
No worries man! I just was having a hard time keeping up with the different threads so wasn’t sure if I missed it.
You got no idea how bad I want off of belts… Lol
PS are you considering helical to decrease the size of the spur gears while increasing the surface area in mesh?
Didn’t know if you were using blank gears and milling them or if your using blank stock and milling.
We will base off original 1:3 design with bit smaller sizes and different gear ratios like 1:3 1:27 1:25 1:24 the drivetrain is done just need to receive wheels to make hub mount. But I can tell you it’s second day I am riding this 1:3 trampa version and I love it!
Nice.
Is it going to be open like that on the final? Or will it have the housing? Just making sure because my biggest reason to get off belts is to prevent debris in the drivetrain/gearing
Yeah it will have housing I just don’t have yet tool to trim motor shafts so instead of drilling hole in the case I am running without it
Man oh man, the mini version for the 107s should also come for SurfRodz RKPs… I know I would buy a set. Hell, I might buy a set of the RKPs to send you to make it off. @Deckoz would you want a set on Surf Rodz over Torque Boards?
Uhm yea @sender lol. I’d totally be down for surfrodz RKP over tb218. But I think we’d need at least 20 people for the first go…or at least more interested then the two of us. Base off what I’ve seen from Kugs in the past…
I’ll even pitch in $ for the set(they’re 30% off right meow) to send to @Kug3lis.
