Done
Here are how mine tuned out.
I have a few different light bars on a few different boards. I am not yet good with step down electricity and what not so I have kept it simple. Just plug my lights into the remote controlâs receiver free channel ports (Example my VESC uses channel 2 then I have channels 1 and 3 free to run the lights) Itâs really good for noobieâish builders like me that are just in our first year (6 months). Just beware the receiver only receives about 5.1v from your VESC. I donât know if that is configurable in the vesc-tool⌠havenât looked around for it.
Look here â $7 on Amazon: https://www.amazon.com/gp/product/B013SSO70Y/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Then I just glue then into enclosure with a hot glue gun. Never failed me⌠been riding the board for about 2 weeks now to work thru snow and hell. Front lights are white and rear are red⌠all on the same circuit so just uses 1 channel on your radioâŚ
this is awesome !!
This is genius how you integrate the LEDs in the enclosure, very nice! I have the same LEDs and was afraid to connect them to the Vesc directly because everytime I read about LEDs I read about resistors depending on voltage. But it seems that these lights donât need that much power so maybe they donât need a resistor. Maybe someone knowsâŚ
Well, not directly into the VESCâŚInto the receiver for your remote. That receiver is powered by the VESCâs PPM port for the remote. Maybe thatâs what you meant
Yeah i know this is some sloppy hot glueâing⌠but i will fix it later when i am in the mood
Haha, perfect @Grozniy, didnât know that, thanks!. My red ones seem to have one, on the white ones I canât find them but maybe Iâm blind. For now I only need the red LED so Iâm good.
I have dual vesc so my plan was to connect 1 or 2 red LEDs to the unused PPM port of the slave vesc, maybe with an additional on/off switch.
Oh directly to the PPM port⌠I have not tried that. Did you measure the volts? When I measured on the receiver connected to the PPM port⌠I got 5.1V
I tried my setup on a my Trampa Carver board as well. The light bar up front fires up fine. But the bar on the rear only has two lights⌠5v not enough I guess Was my own dumb fault really⌠the Amazon listing for that one said 6v minimum. So about 2 of the 5 lights light up.
DohâŚ
Not yet but I have one red LED already running on 4.5V. I modified this light which has 24 white LEDs in the front which I use on my MTB for offroad, I hold it like that:
Funny thing is that i have an electronic on/off switch for a free channel on the receiver. Too bad that I only have 1 channel remotes
How bright are these lights when riding at night ? Good enough ?
The one of my first deck $7 amazon or the one on my carver? I really get about 5-10â range. They are very bright for drivers to see me.
These arenât like my CREE 18W lights i have on another deck. Those are powered directly by a 3s battery and very long distance flood lights thay get 40+ feet
Pretty sure none of the voltage regulators on the VESC can supply enough amperage to power all the LEDs. Personally running mine off a 1S separate from my main battery but using a buck converter can drop the voltage down to something reasonable for the LEDs from your main battery
If youâre running 10S or higher youâd need ones that can support that voltage but anyhow thatâs the gizmo for âefficientlyâ dropping the voltage. Alternative to the buck booster above there are âlinear voltage regulatorâ ICs as well but believe they bleed off power as heat rather than switching a gate open/closed:
Can easily figure out you LED circuit values by putting in the rated voltage/amperage for the LEDs
Pretty handy for under 10s batteries. I found ones that go to 50v or more but the price point gets expensive
And i spoke too soon⌠China to the rescueâŚ
Maybe you could get an esc âsubstituteâ and a lights controller at the same time. I donât know if anyone has tested this, but it looks cool⌠https://www.ebay.com/itm/DIY-Sigle-Electric-Skateboard-Motor-Controller-Main-Board-ESC-Substitute-Kit-36V/132425330743?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D49564%26meid%3Db7ad3bb930ee4db2bc5c4385d5c8961c%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D302558036328&_trksid=p2047675.c100005.m1851
EDIT: Cool concept, but it goes a staggering 11MPH or 18KPH
There are some great ideas in this thread!
I just finished this bad boy today:
Running these lights: https://www.amazon.ca/gp/product/B01M0OXEND/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
For the tail light, I unscrewed the lens off one of them and put some layers of Tuck tape (red siding tape) on the inside and reassembled.
Why did u sell it?
Wow that seems like a super strong light. Arenât you blinding people in front of you ?? But this looks great. I might give it a try.
