This is my currant carbon fiber mtb integrated leds underside and el wire on top
this was taken in the day was sunnyThough this might be useful for some of the UK guys here, looks like this torch could be quite a good headlight and with a single lithium cell i would hope shouldn’t suffer form the batteries rattling loose.
https://www.aldi.co.uk/12w-led-cree-rechargeable-torch/p/077223150397000
From experience @lowGuido I can tell you the flicker (for me) was caused by the battery shaking around. The spring on the inside is not very strong relative to the weight of the battery. So… Stronger spring? or Just stretch the spring out a bit more so it applies more pressure
Anybody have recommendations? Looking to buy both front and rear lights to add up to $20.
My old board snapped while jumping off a wall forgot I had a pic integrated led and inlay el wire again
Just wanted to share my lights set up.
If I had money to spare I would have gone with Shred Lights for sure - its just simple and works!
DIY method I have decide to use cheap Ebay LED torches P Clip clamped to the truck kinda like Shred Lights.
Lights - £2.14 each plus shipping
Rubberised P Clips - approx £2 for pack of 2-3 as two different sizes are needed.
25 mm to mount at front ( thicker) part of the torch
14-15 mm for the slimmest part of the torch
Here are pictures of torches just with 1 P Clip. Second one will be mounted soon ( waiting for delivery). This will ensure that they don’t come off or rattle while riding.
Since I have angle risers I had to get 50mm M5 bolts.
I also have ordered rear red torches - same brand and model
Total Cost - £4 per light x 4. Shred Lights - £75 for set of 4 …
hi thanks for the links. I have just order the same do you have the reference for a red one ?
Just for what its worth those P clips will break off from the vibration of skating.
@sayreul here is link to red one. https://www.ebay.co.uk/i/222462250075
Unfortunately as the torch has screw on bottom ( for battery AA replacement) it unscrews itself off while riding and also on off butting is there making it either switch off the flights or change it to flashing mode by itself . All due to vibrations.
I haven’t had tome to look into fixing it somehow so I took lights off for now.
Also the P clips due to vibrations rattle against truck base and are horribly loud ;(
Might need to put a bit of rubber between them.
Perhaps I will tape on the screw on part of torch so it doesn’t come off. Not sure if it will work at all. Fuc**g vibrations!!! ;(
I have a headlamp I’m thinking of mounting to the board. It’s really bright and durable. My kids actually brought it in the tub with then and it still works. I barely use it so I figure it would be good for the board. I also made an altoids light that I want to find a place for.
Simple led from eBay https://m.ebay.co.uk/itm/6-Modes-COB-1-LED-Bike-Bicycle-Front-Rear-Light-USB-Rechargeable-Battery-Torch-/332172755143?varId=541208589565&txnId=1445095910014
Energizer headlamp was super easy to put on lol. I just wrapped it around the trucks like a hair scrunchy.
That’s a cute doggy. Does the headlight remain steady ? tissue looks close to the wheels. Careful not to wheelbite.
Edit : Oh, Altoids case ! You do DIY headphone amps ?
I haven’t actually got it working yet with it on. My remote decided to stop working. I can push it over some but the wheels spin fine
@Silverline Do you have close ups of how you have attached lights to the trucks? Do they not wiggle around from vibrations?
Blue channel Headlights/tailights
After grip
Front leds
Rear
Jetson mobile? Magic school bus? Who knows
My new rear light design, still need to paint, wire up all LED’s and fill the cavity with clear resin
Maybe I will sand the lens to give a frosted fell and improve visibility in daylight
siiickk!
Would you mind posting which leds you used? I’ve been trying to do the same thing but have been unsuccessful in my search of bright leds
