Would you mind posting a picture from the top view? I’d like to see how the wheel base of the MatrixII trucks look with the caver (they look a little narrow with Trampa mtb deck imo).
Beautiful build btw!
Ok thanks … your kit goes that it’s a bomb …
@jbalint1122 I built this board 4 months ago. I wanted to describe construction on the forum, but I always lack the time to do it… I will try to do it in January
@benjammin a photo from the top view with the first version of the motor mounts
and with latest version of motor mounts
Fabolous! Such a nice build. Waiting for that build log.
Thanks man! Very cool
The evolution
That’s true … this mountainboard had many versions of motor mounts. Every next one is better, so it’s Evolution
This battery solution looks great. Are the designs on thingiverse? how does it deal with the wet?
I really liked the Hex cutout crossbars on your early printed one, very stylish.
Did it Held up or did it brake?
Over the weekend I did the first real test, the ESCs are not as noisy as I thought and your motors holder is perfect .
Maybe I have to add cooling fans …
I’m not sure if I can find a clear answer. Are the 3d files publicly available? Also, what brand or headlight is that?
The one picture in this post from the 18th of January.
your first built enclosures is similar
Two questions. Is the ESC and the Software that you mentioned still the best or have you found a better combination? What do you think about the “Alien Power System” ESC:s? This is the best tread so far, Keep up the good work!
