Wow nice job integrating the heatsink… Too bad I want to top mount my emtb I know I’ll never get something that slick with these two left hands
The heatsinks are only suitable for two single focboxes, it wouldn’t work on the Unity or any other ESC
How are they attached to the enclosure? Epoxy?
Yes. It’s epoxied to the enclosure
How is the KutThaka enclosure coming along?
It’s going to take some weeks to finish it
There’s actually plenty of space for a 12s3p in your single stacked enclosure for the Jet spud.
Good luck fitting it to the deck without sanding or shaving it down
You could use foam between the deck and battery and a window gasket (which I recommend one should do anyway).
People are having trouble with the height on these enclosures?
No, but when my battery was in the single stack, I guess I may have had a litle more foam around my battery than that(I know yours is not built yet but I asked for my pack to be waterproof** ), I was having clearance issues with bolting the battery to the deck evenly, without putting high amounts of pressure on the enclosure
** As much as possible
There is plenty of room between the batteries and deck on the Spud SS enclosure, no clearances issues at all AFAIK.
@chase the Spud SS 12s3p is great but you won’t have space for a BMS unless you mount it over the cells, I haven’t tried that but it might be a tight fit.
That’s a 12s bms in the pic on the side opposite of the vescs.
Wow that’s a pretty small one, can you share the link where you got it from?
Yep just bestech
I tried single stack 12s3p with bms on top (1,6cm high bms) first it looked like it fitted when trying in the enclosure, but because of the decks curve it’s not possible
Lol @dareno was just telling me I needed to switch up to a full length Evo, and you made a V2 enc. it’s a sign lol
Here you can se how the different it will make for the clearence for the motors:
I got some Subsonic decks today to start working on the enclosures. The decks are exceptionally beautiful and pretty high quality.
What deck would you like the enclosure for first?
